-   -   915 shifting noise (http://forums.pelicanparts.com/porsche-911-technical-forum/740552-915-shifting-noise.html)
urseppos 03-23-2013 08:03 AM
915 shifting noise
Hello yet again,
The other early morning heading to cars and coffee and driving hard, I was shifting from 4th to 5th and as I removed 4th and started going across to 5th it made a loud snapping noise as if something plastic had broken.
The car still shifts fine but every so often, especially when not expecting it, SNAP ! What could this be ??? The other thing is that I am now clipping reverse as I down shift from 5th to 4th as well :confused:
Any and all help would be greatly appreciated.
Cheers !
john walker's workshop 03-23-2013 08:28 AM
check the coupler bushings.
theFONZ 03-23-2013 08:35 AM
Yep, coupler bushings. Pull up the carpet on the rear of the center tunnel and remove the access plate.
If you end up needing new bushings, a forum member here sells good ones.
