cycling has-been
bkreigsr's Avatar
BRAKE BLEED PROBLEM (after p-valve gut)
After gutting the proportioning valve on my 85, I can't get a good pedal.
I went around the car 3-4 times with the pressure bottle (@13 lbs) hooked up to the reservoir.
I think the problem is that the valve itself is holding a trapped air bubble.
Does that sound right?
Anyone know of someone making a replacement hard line with 2 female fittings to fill in for the valve casing?
thanks for your input
Bill K
Old 03-25-2013, 07:49 AM
kodioneill's Avatar
Bleed it the old fashion way. Have someone pump the pedal 10 times hold it down then bleed three or four times on each wheel. Start at the r/r then l/r then r/f then l/f.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-25-2013, 08:18 AM
schumicat's Avatar
is the master cyl. went dry in the process I would bench bleed it.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-25-2013, 09:06 AM
cycling has-been
bkreigsr's Avatar
I had a board on the pedal so the only fluid I lost was from the valve itself.
Had not though about the old fashion two man method. I'll give it a try next time my son visits. I did a gravity bleed at the back and it got a little better.
Old 03-25-2013, 09:20 AM
