Keen 915 operator
felix83's Avatar
Starter won't engage, steering lock? - '82 SC
Sometimes, when turning the key from the 'run' to the 'start' position, it won't spring back to the 'run' position, and the starter won't engage. Does this mean my steering lock is FUBAR'd or would simply replacing the electrical part do the trick?
/Felix
'82 Porsche 911 SC Coupe
'77 Porsche 924 Targa
Instagram: @orebro.classics | @924.resurrection
Old 03-27-2013, 05:55 AM
theiceman's Avatar
The spring and contacts are all held in the electrical part .. look at it this way .. i would certainly start there before you get the sticker shock of the whole mechanical piece. I dont think thats it though.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 03-27-2013, 05:57 AM
My issue at times when the lock is binding is I can't move the key even to the run position. I rock the steering wheel and it seems to release. I think it sounds like you have an ignition switch issue.
Old 03-27-2013, 07:50 AM
Keen 915 operator
felix83's Avatar
Sounds a bit like this chap's problem. Maybe this thread gives you some pointers:
Ignition lock won't turn to start
/Felix
Old 03-27-2013, 01:25 PM
Exactly what happened to me. I searched and found the thread that is linked above and also this one: Ignition switch - inside to fix START lockout
and one more: Ignition switch springing problem
You can narrow it down to the electrical part of the switch or that little disc separating from the tumbler by removing the electrical part of the switch and testing it with a flat screwdriver into the slot. If you have a good spring action there then the problem is with that disc/tumbler.
Old 03-27-2013, 09:10 PM
