-   -   Need to replace oil return tubes on '86 Carrera. (http://forums.pelicanparts.com/porsche-911-technical-forum/741538-need-replace-oil-return-tubes-86-carrera.html)
PabloX 03-28-2013 05:03 PM
I'm going to get the steel two piece replacement tubes.
The question is, on an '86, is it absolutely necessary to remove the heat exchangers on this car?
I also need to replace the lower valve cover gaskets.
PDACPA 03-28-2013 05:15 PM
It is not necessary to remove the heat exchangers. I just did it a month or so ago and did not remove them.
On the Driver's though you have to remove the oil return tube that is closer to the rear of the car in order to get the one towards the front of the car in. The passenger side is no issue.
PabloX 03-28-2013 05:58 PM
Excellent! Thanks.
I guess I'll put the MAPP torch away now.
My next question, how long a tool is needed for the barrel nuts? The one our host sells is ridiculously expensive for what it is and I'd like to find a cheaper alternative.
plumb4u2 03-28-2013 05:59 PM
I also replaced mine about 2yrs ago and did not remove anything
It's not simple but not horrible either
PDACPA 03-28-2013 08:36 PM
What barrel nuts? All I used was some pry bars and some hose clamps to give me some leverage to get the oil return tube to spread fully.
Pry Bar Set - 4 Piece
Here is another Pelican's tips that I followed. The only thing I did different was move those hose clamps further towards the ends of the tubes. Being in the center like that did not give me enough leverage to sink both ends in tight.
http://forums.pelicanparts.com/porsche-911-technical-forum/631450-oil-return-tube-replacement-tip.html
Jcslocum 03-29-2013 07:20 PM
Follow the instructions in the last link. Did these today and didn't have the 2nd hose clamp. A real bugger to do without!
Scott R 03-29-2013 07:36 PM
Friends don't let friends get injured by HF tools.
http://forums.pelicanparts.com/uploa...1364610997.jpg
PDACPA 03-29-2013 08:11 PM
LOL @Scott - Northern Tool was too far a drive and I was in the HF area. Not much to go wrong with a bent piece of metal and a plastic grip.
Nathans_Dad 03-29-2013 08:42 PM
Harbor Freight has a set of long hex keys with ratchet ends that work well on the barrel nuts. Kroil is your friend!!!!
Scott R 03-29-2013 09:15 PM
I keep this as a reminder in the "hall of shame." The missing piece was removed by a skilled ER technician.
http://forums.pelicanparts.com/uploa...1364616921.jpg
PDACPA 03-29-2013 10:16 PM
Scott - how the heck did that happen? And where was it stuck in you?
