Need to replace oil return tubes on '86 Carrera.
I'm going to get the steel two piece replacement tubes.
The question is, on an '86, is it absolutely necessary to remove the heat exchangers on this car? I also need to replace the lower valve cover gaskets.
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
911 + 129 = JOB
It is not necessary to remove the heat exchangers. I just did it a month or so ago and did not remove them.
On the Driver's though you have to remove the oil return tube that is closer to the rear of the car in order to get the one towards the front of the car in. The passenger side is no issue.
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
I guess I'll put the MAPP torch away now. My next question, how long a tool is needed for the barrel nuts? The one our host sells is ridiculously expensive for what it is and I'd like to find a cheaper alternative.
I also replaced mine about 2yrs ago and did not remove anything
It's not simple but not horrible either
Justin 84 Carrera Targa 98 F-150 4x4 |
911 + 129 = JOB
What barrel nuts? All I used was some pry bars and some hose clamps to give me some leverage to get the oil return tube to spread fully.
Pry Bar Set - 4 Piece Here is another Pelican's tips that I followed. The only thing I did different was move those hose clamps further towards the ends of the tubes. Being in the center like that did not give me enough leverage to sink both ends in tight. Oil Return Tube Replacement Tip
Project Addicted
Follow the instructions in the last link. Did these today and didn't have the 2nd hose clamp. A real bugger to do without!
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
911 + 129 = JOB
LOL @Scott - Northern Tool was too far a drive and I was in the HF area. Not much to go wrong with a bent piece of metal and a plastic grip.
Harbor Freight has a set of long hex keys with ratchet ends that work well on the barrel nuts. Kroil is your friend!!!!
Rick 1984 911 coupe |
911 + 129 = JOB
Scott - how the heck did that happen? And where was it stuck in you?
