Norm Faustino's Avatar
Sorry guys, had to post these here.
Sorry guys I tried to send these to a fellow pelican "guards red 911" Who was interested in seeing how I did my airbox with cam-locks but in the PM screen it has to be linked somewhere if you want to send photos, so I will put them here and for anyone else that's interested in doing theirs the same way, here is how I did mine.
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 03-27-2013, 10:20 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
great idea..
Old 03-27-2013, 08:26 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Why sorry? that's great work, better than those ugly straps. good job brother
'85 Carrera Targa
PCA/POC
Old 03-28-2013, 01:09 AM
Thanks guys, for the nice comments. It's still in prototype status but I need to get this car on the road, so I will make it pretty later. Right now, it just needs to be functional.
Old 03-28-2013, 06:14 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Those look very functional and function above form I say. Can you tell me a source for those cam locks. Thanks
Old 03-28-2013, 07:08 AM
Banned
Really any place that sells fasteners (such as the following) -
http://www.amazon.com/s/ref=a9_asi_1?rh=i%3Aaps%2Ck%3Adzus+fasteners&keywords=dzus+fasteners&ie=UTF8&qid=1364483712
Old 03-28-2013, 08:14 AM
Josh D's Avatar
Really nice work! That engine is sure gonna be purdy!
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 03-28-2013, 08:25 AM
Thanks Josh, The fasteners I used are actually Dzus fasteners obtained from an Ebay seller called Kurveygirl.com. I know, my mind went somewhere else too... anyway you'll want to get the receptacles and fasteners as a kit and they are shown that way on their site. Good luck guys!
Old 03-28-2013, 10:54 AM
redturbo911's Avatar
That is a cool looking airbox.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 03-29-2013, 07:00 AM
Scott R's Avatar
Anytime you feel like posting something cool like that, please don't hesitate. Of course now we need details.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-29-2013, 07:54 AM
I question if going from continuous straps to concentrated point loads on the lips will over time fatigue the plastic.
Porsche Photos by kach22i | Photobucket
It is an elegant and simple solution, just wondering if the clips should not be strips going the full depth of the airbox, thereby distributing the compression loads over a larger area.
Maybe more holes and rivets would be worse than what you currently have, I'm not sure.
Old 03-29-2013, 07:55 AM
Scott R's Avatar
George, I have no idea if the side would break or not, but I was going to add that the normal clips attach to that lip and it's always the clip itself that breaks of and not the lip.
I was thinking after you posted this how brittle some of my old airboxes are. The one I replaced recently had the right side breather/filter bung cracked off just due to age.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-29-2013, 08:01 AM
I guess only time will tell. Heck, even the factory engineers miss stuff resulting in vehicle recalls. If it helps, I will add that the lip part the airbox is actually sandwiched between two pieces of sheet metal and the lip is pretty pliable and should last a long time. If not, there's always the plastic weld kit. Actually in this instance, it's more of a tension (pulling) load.
Old 03-29-2013, 09:35 AM
Dzus fasteners are some good stuff. They actually use them on race cars to hold on removable body panels. Bisimoto is using them on his RWB-style 911 to hold on the rear bumper for easy removal to reach his turbos. I have some Dzus fasteners (a flush style though) on the carbon fiber hood on my Boxster. They have worked very well for me for the last five years! I did not get mine on eBay, I got them at an on-line race shop. Just throwing out another source - check any of your on-line auto racing supply shops.
Kirk
Old 03-29-2013, 09:51 AM
.......I will add that the lip part the airbox is actually sandwiched between two pieces of sheet metal .
I did not know this, reconsidering my doubts now.
........... Actually in this instance, it's more of a tension (pulling) load.
I agree, was thinking about this right after I posted it. The clips are compressed together, causing tension in the adjacent connections and areas.
Like someone said, time will tell.
I like the effort to innovate even though it's a bit more bling than I normally like.
Originally Posted by Scott R View Post
........... the normal clips attach to that lip and it's always the clip itself that breaks of and not the lip.
That is a good thing to keep in mind when critiquing the design.
Old 03-29-2013, 10:20 AM
