Breeang's Avatar
Question Bilstein inserts
I have replaced my strut insertsand have two questions:
1 I have used Bilstein inserts and I think I read somewhere some while ago that you do not need the rubber bump stop tube on the top of the insert as Bilsteins already have a stop built inside . Is that correct?
2 In the Porsche factory parts catalog, around the top of the strut shaft, immediately above the dust cover there is shown a strut spacer (item #6). This item appears to have been left off the part number list on the opposite page and no one seems to stock it (discontinued). I never had any on my supension before I started so is this spacer necessary? If it is, does anyone have any dimensions so I can find a substitute?
I thank you .
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 04-03-2013, 10:11 AM
schumicat's Avatar
on 2 the spacer is apparently something they put in for the US market due to US DOT bumper height requirements, and it is not really needed.
on 1, I used the bump stop on mine. there was a double bump stop (with thin part in middle) and I cut it in half and only used half. I think I recall reading that was how some recommended it be done but am not really certain.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-03-2013, 10:54 AM
Breeang's Avatar
Thanks, both of those answers make a lot of sense. These cars are like Rubic's Cubes with wheels. Thanks again
Old 04-03-2013, 11:28 AM
