Dual oil cooler pressure loss
Do you need to do any modification to the oil pump in order to handle an extra oil cooler.
I have seen the Elephant Racing set up and I am wondering if the oil pressure will drop by adding this extra cooler.
Old 04-03-2013, 12:58 PM
kodioneill's Avatar
I'm no expert here but I don't believe that it would matter. I see many cars with two oil coolers with no pump modification.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-03-2013, 02:26 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
On the scavenge side you are dealing with flow...not pressure.
The return side of the pump flows back to the tank...which is a big cavity...so th only way for the scavenge side of the system to build up any real pressure is if the tank, filter, or a hose is pinching off the flow.
Theoretically...you could put a dozen coolers in the return system as long as you understand the flow factor.
Pressure is built up when a restriction is encountered...so...the overall flow is determined by the smallest hole in the line.
Bob
Bob Hutson
Old 04-03-2013, 03:34 PM
So the oil coolers are placed after the oil passes through the engine ?
This cooled oil goes to the oil tank ? or to the engine bearings, etc. ?
Do you have a flow diagram ?
Old 04-03-2013, 04:00 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil Cooler
Hope this helps:
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-03-2013, 04:45 PM
Thanks,
Now I think I understand how this system works.
Old 04-03-2013, 10:17 PM
