Gear oil for 915 trans
So there are lots of useful gear oil threads that I have researched but I have not found the specifics for my question... so another oil thread.
Is one of the three or four recommended gear oils preferred for a car that is mainly used for track days? If it matters - mated to a 3.2L in a light car.
Old 03-28-2013, 03:57 PM
Peter Zimmermann's Avatar
I ran Kendall dino 80w/90 GL-5 with LSD additive in my PCA Club Race car, my SCCA E/P 914, and a large number of time trial/auto-x cars that I've driven/owned/maintained. Also used it exclusively in customer cars at my shop for 25 years. It's not just good; it's great.
Keep the Shiny Side UP!
Pete Z.
Old 03-28-2013, 04:04 PM
gearhead
Same two gear oils that come up in all the other discussions, Swepco or Kendall. which one? Do you like ale or lager? Same sort of question, IMO.
If you run an LSD in a racecar I personally recommend that you do NOT run an LSD additive. Just makes it slip more which is counter to having an LSD lock. LSD additives are NVH items and not performance adders.
Lastly, the thing to remember on your racecar is up your service interval. No more than 4-6 race weekends between gear oil changes. That frequency is more important than which oil you actually choose. And given that frequency, if you want to experiment and see if you like the shift quality of one over the other, you're going to change it more than once a season and can see for yourself...
Regards,
Matt Monson
Guard Transmission llc
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-28-2013, 04:17 PM
Originally Posted by Peter Zimmermann View Post
I ran Kendall dino 80w/90 GL-5 with LSD additive in my PCA Club Race car..
Is this the same as Kendall NS MP Hypoid Gear Lub - 80-90?
Old 03-28-2013, 04:27 PM
I'll have a lager.
Jon B.
Vista, CA
Old 03-28-2013, 04:40 PM
Banned
Regards,
Matt Monson
THis is excellent advice. For my street-only car, Kendall made the shifting MUCH more smooth when I switched from SWEPCO. If I were to race it, I might make a different choice.
Old 03-28-2013, 04:48 PM
howard freeman's Avatar
Pilsner Urquell for me, I am thirsty now.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 03-28-2013, 04:49 PM
My experience... Swepco slightly quieter. Kendall better shifting.
Old 03-28-2013, 05:00 PM
Yep. You must decide, regarding LSD, what you want to do - if you have LSD. Our host sells Kendall Hypoid, and Kendall dino w/LSD additive added. Both are 80w/90.
It seems like beer time, think I'll have a Spaten Lager...
Pete Z.
Old 03-28-2013, 05:06 PM
Red Line Service
Marc Bixen's Avatar
All this talk of oils is getting um, you know. I'll have a single malt. Matt I know that wasn't on the menu. Kendall for me and John if you get up to L.A. I'll buy you a lager.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 03-28-2013, 05:22 PM
kwikt 911's Avatar
I tried Kendall but went back to Swepco. I thought it shifted better with the Swepco. Wait a minute..... maybe it was the color I liked
Old 03-28-2013, 05:39 PM
Functionista
manbridge 74's Avatar
One might consider 75w140 if there is a lot of balkiness due to slop. Rebuild likely in the future though.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-28-2013, 06:01 PM
Sboxin's Avatar
Regards,
Matt Monson
Is the Moly additive in Swepco 203 considered a LSD additive?
And, therefore use 201 with Guard LSD?
Edit: Added from a reply from MAtt
- "Do NOT put 203 into your gearbox! "
TIA,
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 03-31-2013, 02:06 PM
Lager, and I'll take a Augstiner. Sorry I saw the bier reference and I had to put my two cents. Btw Kendall is my 1st choice. Swepco is a very close second. Either way can't go wrong.
Old 03-31-2013, 02:38 PM
BMWonly's Avatar
Here are my $0.02:
Bought a 1980 SC about 1 1/2 years ago. Had a PPI done, and had them do a transmission service. They put an unknown gear oil in, plus BG MGC:
BG Products, Inc.
I drove it home 950 miles (Tucson to Sacramento), and thought the transmission was in pretty good shape (original 915 with 97k miles).
Still wanted to try the famous Swepco, and was a little disappointed. Shifting was more metallic and much less smooth than before, as if the oil is too thin. So I added BG MGC, and the smoothness came back, feels like the syncros are coated with a protective layer. This probably saved my transmission.
After tax season I will try Kendall, first without BG, and then see what BG does to it.
Dieter
1966 912 Hot Rod
2001 BMW Z3 Coupe 3.0
1980 911SC (sold)
Old 03-31-2013, 02:41 PM
Reifle's Avatar
What about adding Moly Slip to the tranny (915) to quieten down things. I used this years ago in my cars - VWs, Audis, etc... Did a great job then how about now...
'77 Porsche 911S
Old 03-31-2013, 03:54 PM
Racer
winders's Avatar
It didn't save your 915........where does this stuff come from??
Scott
Old 03-31-2013, 04:07 PM
Straight shooter
Lapkritis's Avatar
Royal Purple replaced Redline in my car... less notchy shift feel with RP.
+1 for fluid change often.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-31-2013, 04:19 PM
AutoBahned
RWebb's Avatar
the 915 uses baulk ring syncros and need some friction to work properly
use Swepco and no additives
or be experimental and use Kendall and no additives
change it every few years
Old 03-31-2013, 08:01 PM
Straight shooter
Lapkritis's Avatar
Same as the VW cousins. One of the best is Pennzoil Sycromesh on those... the RP is a bit thicker. Glazing the brass ring from running fluid too long and/or excessively wearing the ring is the most common problem.
Old 03-31-2013, 08:33 PM
