-   -   Question on WEGO III AFR (http://forums.pelicanparts.com/porsche-911-technical-forum/742938-question-wego-iii-afr.html)
giovanni86 04-04-2013 01:30 PM
hi all,
in the next days I'm going to install a WEGO air/fuel ratio gauge. On the manual I am reading that a parameter called "RPM Pulses/Rev" and one called "RPM Debounce" must be setted.
Has anyone already gone through this? Any idea of the correct values for a porsche engine?
Thanks a lot
Bye
Giovanni
giovanni86 04-05-2013 12:21 PM
bump
1986911 04-05-2013 04:32 PM
I have a Wego IV.
My debounce is set to .50
My Rpm pulses are set to 3
You set it on the computer then load it to the Wego unit
Data logging interval is .60
I got this off their website. Link to pdf is very helpful too
RPM Debounce – RPM signal filtering in
milliseconds (msec). Use the default value of 0.50
msec for most applications. Ford 4.6L modular V8
engines will require a value of 3.5 msec. Suzuki
Hayabusa models will require a value of 3.0 msec.
If the RPM trace appears noisy, try a higher RPM
debounce value.
http://www.daytona-sensors.com/download/WEGO_Log_Instructions.pdf
giovanni86 04-06-2013 01:34 AM
thanks a lot,
the manual is very good, but I thought that few hint from someone that is already using the WEGO, could be very helpful
Any other suggestions?
G.
dicklague 05-28-2013 05:14 PM
Giovanni,
I used the same setting from the website. I love the Wego IV.......great AFR for the price. I have had mine for 4 years and not problems whatso ever.
Great unit.
How is it working for you? Will be glad to answer any questions. Sorry I missed your PM
