Question on WEGO III AFR
hi all,
in the next days I'm going to install a WEGO air/fuel ratio gauge. On the manual I am reading that a parameter called "RPM Pulses/Rev" and one called "RPM Debounce" must be setted. Has anyone already gone through this? Any idea of the correct values for a porsche engine? Thanks a lot Bye Giovanni |
bump
I have a Wego IV.
My debounce is set to .50 My Rpm pulses are set to 3 You set it on the computer then load it to the Wego unit Data logging interval is .60 I got this off their website. Link to pdf is very helpful too RPM Debounce – RPM signal filtering in milliseconds (msec). Use the default value of 0.50 msec for most applications. Ford 4.6L modular V8 engines will require a value of 3.5 msec. Suzuki Hayabusa models will require a value of 3.0 msec. If the RPM trace appears noisy, try a higher RPM debounce value. http://www.daytona-sensors.com/download/WEGO_Log_Instructions.pdf
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS 1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE. 2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK" Last edited by 1986911; 04-05-2013 at 04:35 PM.. |
thanks a lot,
the manual is very good, but I thought that few hint from someone that is already using the WEGO, could be very helpful Any other suggestions? Thanks G. |
Giovanni,
I used the same setting from the website. I love the Wego IV.......great AFR for the price. I have had mine for 4 years and not problems whatso ever. Great unit. How is it working for you? Will be glad to answer any questions. Sorry I missed your PM
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
