-   -   Help for A/C removal sc 1983 (http://forums.pelicanparts.com/porsche-911-technical-forum/742987-help-c-removal-sc-1983-a.html)
wwest 05-27-2013 06:12 PM
Originally Posted by billybek (Post 7410717)
Should the Spal fans be removed as well?
Sorry, I couldn't help myself.....;)
"Spal" fans are typically only found in the 996 or 997 911 series, generally for providing condensor/radiator cooling airflow when not "at speed".
billybek 05-27-2013 06:54 PM
Originally Posted by MathieuD (Post 7465028)
Coming back to my A/C removal on my 1983 SC I started 3 months ago....
http://forums.pelicanparts.com/uploa...1369696398.jpg
Is that boot on the CV punctured?
You could pull the bolts individually and clean them up and the bolt hole and re install them with schnorr (sp?) or Nordlock washers.
If the boot is ripped you may need to do a little more work.
