-   -   Running CIS on 80-83 3.0L w/o using brain/o2 (http://forums.pelicanparts.com/porsche-911-technical-forum/74309-running-cis-80-83-3-0l-w-o-using-brain-o2.html)
GMR911 07-11-2002 09:15 PM
Hi, Can any one give me info on running a 3.0 L without the brain/ oxigen sensor set up. What would be required to run this way and would it work properly. I am looking at installing a 3.0 L in my 77S and one mechanic said you could install it without the brain/02 setup or even use the complete CIS setup off my 77S on the 3.0 L. Any thoughts on this, Thanks
stlrj 07-11-2002 11:32 PM
I don't know about NY but here in CA it wouldn't smog.
Joe
Talonz82 07-12-2002 03:37 AM
Hello, you can eliminate some of the circuits but not all, the ECU controls the frequency valve and if it does not work, the car will run, but very poorly, I can send you a electrical diagrahm if you need one.
I have a 80 3.0, I set the mixture with the O2 disconnected and leave it disconnect for overall driveability
Peter
Sean Hamilton 07-12-2002 09:53 AM
GMR911
email fellow member "Hladun".
you'll find him in member search under - H - page 5.
He's done some good tech articles on CIS mods.
