1980 911 removal of centre cabin temp control & box
I have just bought a 1980 911 SC Targa.
Both the rear and front blower motors were u/s.
I have repaired the rear hot air blower and am waiting for the front cool air motor & fan from Pelican.
In the mean time I need to remove the plastic centre console with the temp. control knob surrounding the handbrake to check on the cable link from the little servo motor which appears to be working to the cables going to the 2 rear hot air flapper box's.
The flapper box's work and the round flat sheet metal vane doors are free and can rotate, Ive lubricated the cables and Ive put a scope up the tunnel from the rear seat tunnel up to the little lever that is operated by the servo motor. I can see the servo connecting lever move from within the cabin inside the plastic cover and also see movement of the lever up in the tunnel/mezanine floor space, but the cables are not moving down to the flapper box's. I think that something has come adrift at this connection point, but looks impossible to get to.
I am hoping someone can provide a detailed description on how to remove the plastic housing and other bits to get down to the lever to cable connection area.
Help is required asap.
thanks
Eric
Old 01-02-2013, 05:14 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Auto heat.
thanks
Eric
Remove/pull the temp knob from the floor mounted heater control, then the nut, then the floor mounted control cover which is held down by four screws.
All covered in the Bentley.
Gerry
pm me as needed.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-02-2013, 05:32 PM
I generally remove the access cover on the right side of the box, leaving the box in place. It's easier to do with the right seat removed. That sounds like a big deal but it takes about 4 minutes to get it out.
JR
Old 01-02-2013, 06:53 PM
emac's Avatar
Eric I removed the entire console in about ten to fifteen minutes. And it was my first time take ur time very straight forward
Ernie
Old 01-02-2013, 08:24 PM
Always Be Fixing Cars
If anyone's still reading this thread... any tips on getting the central heat console out of an 87 Carrera with manual heat? I can see that there are wires soldered to the 3 position knob so I'm guessing that there must be a way to disconnect the knob from the console? Or maybe there's a snap fitting on those wires that is burried under the carpet hidden from sight? Right no I can't figure out how to de-wire this puppy.
There is a screw in the center of the 3 position knob but it doesn't seem to want to back out. Don't want to damage anything here.
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 04-06-2013, 02:48 PM
