Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Windshield leak?
I have a question about my winshield seal. I have a leak and when I inspected it I noticed the seal is not holding the windshield tight into position...and just a little pressure against the glass will cause movement. Will a new seal correct this, or can a glass shop do something with the current seal? The current seal looks ok...but maybe it's worn out.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 07-13-2002, 03:36 PM
Montana 911
k9handler's Avatar
Bump....
Also, if I order the seal through Pelican is this a DIY or will I need to take it to a shop for the install?
H.D. Smith
2020 Yamaha YFZ450R
Old 07-13-2002, 10:17 PM
Sounds like a good time to check for the dreaded rust. A leak & movement of the windshield doesn't sound too encouraging. It's not too hard of a job to replace a windshield. Do a search.
Marv Evans
'69 911E
Old 07-13-2002, 11:01 PM
I don't know about you glass moving around. But the factory recomends that you put 2 beads of urinthane around the outside. One on the windhield side and one on the body side. You might go to a glass co to have that done first if it needs it.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-14-2002, 05:09 AM
Montana 911
k9handler's Avatar
Thanks everyone!
I had a friend look at it and together we noticed zero rust, that I expected since the car is very clean and rust free. But we did notice there was also zero beads of urinthane around the outside...so I bet this is the issue. I am going to take it and have this done at a shop Monday.
Thanks again.
H.D. Smith
2020 Yamaha YFZ450R
Old 07-14-2002, 07:02 AM
