Nico911's Avatar
Dome light still not working
Hi Pelicans.
I just installed a brand new dome light unit (the original was broken) with new bulb and... still no light, in any of the 3 way switch position.
My P is a 1985 Targa, dead stock.
Any idea ??
1985 911 Targa (sold)
2001 996 Twin Turbo (sold)
2001 996 C4
Old 04-24-2013, 06:12 PM
fred cook's Avatar
interior light
Check the door switch to see if it is making ground. It will unscrew from the door frame. Be careful to not let the wire pull out of the back of the switch. Once you have access to the wire, try grounding it directly to the door frame. If that doesn't work, check the fuses. I hope this helps!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-24-2013, 06:25 PM
Nico911's Avatar
Sounds good Fred !
2001 996 C4
Old 04-24-2013, 06:27 PM
Pure Awesomeness
szyzygy's Avatar
those rubber nipples tear so easily!
I had the same problem. Pulled 'em out, pull it open, sand the contact a little, put it back together. Good as new. Except for the nipple!
1977 Porsche 911
Old 04-24-2013, 06:43 PM
Dome light operation.......
Nico,
The dome or courtesy lights work three ways.
a). Door switch........uses ground to turn the courtesy lights.
b). Manual switch......supply power to light bulb sockets.
c). Off position
Test the dome light terminal/s for presence of:
a). Ground contact
b). Power (12 volts)
You need these two things at the same time for the light/s to work.
Tony
Old 04-24-2013, 06:49 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Targa Bar Light.
I don't think It's the fuse, but here's the fuse panel:
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-24-2013, 07:50 PM
Dial 911
A horse with no name's Avatar
power...?
Hi ...I just got mine working ('86 Cab) ...Just in addition to the other suggestions:
Have out checked to see if you have power at the light (Black wire) with a volt meter? If you have, you may have put the wires back incorrectly...The solid brown is your ground and the brown with a white stripe is for your door switch...If wired incorrectly it will not work properly.
In my case the pins in a connector were dirty which was only giving me 10 Volts. Once they were cleaned-> steel wool or? - all was well.
It's a 2 wire harness coming out of the car that has 1 black and a brown with a white stripe. With your trunk open and looking down from the outside left fender - you will see it among a couple of other harnesses around the left trunk strut.
Here is a photo of the connector...I hope one or more of the different posted suggestions works for you.
Originally Posted by Nico911 View Post
Hi Pelicans.
Any idea ??
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 04-24-2013, 11:01 PM
