supercarrera82's Avatar
3.0 needs rebuild, found a good price on a 2.7 ..????
I have a 1982 911 sc and the 3.0 needs a rebuild, while looking around I found a 2.7 off a 77, for around $2000k shipped, good compression. All it needs is the CIS system and alternator, I was thinking of replacing it with the 3.0 for the time being while I rebuild it, while changing the obvious on the 2.7 prior to putting it in. What you guys think? good of bad idea? thought it was too good a price to pass up as a temporary option.
Old 04-02-2013, 01:42 PM
I wouldn't do it. In the time you'd spend swapping motors and fixing all of the issues to make the 2.7 run correctly, you could have the 3.0 rebuilt, if a competent shop was doing the rebuild. You's also be out some money that could be better spent.
JR
Old 04-02-2013, 01:55 PM
theiceman's Avatar
nooooooooooo
the 2.7 is a POS
someone knows that already , stripped off the CIS and alternator ( the only working bits ) and left you the crapped out case...
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-02-2013, 01:57 PM
Functionista
manbridge 74's Avatar
I'm thinking the price is to high for what is missing unless he has paperwork on case work etc. When and if I ever sell my extra 2.7 it will be running on a stand or in a car for those wanting to see that it is not a POS.
Too many unknowns make it a possibility that you'll be doing two rebuilds.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-02-2013, 02:25 PM
thanks for your input, i passed on it, ill do a 3.0 rebuild and save the 2.7 money and get some carbs.
Old 04-08-2013, 09:37 AM
Taking it apart is easy
Jerome74911S's Avatar
Originally Posted by theiceman View Post
nooooooooooo
the 2.7 is a POS
Rubbish. You can't make this statement as a blanket dismissal of all 2.7s and be taken seriously. One that is 'fixed' is a fun engine with peaky power. Mine is in it's 40th year and is running strong - how is that a POS?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 04-08-2013, 11:22 AM
Functionista
Mine is also in its 40th year and going off the large binder of receipts that came with it, only the valve guides have been replaced in the way of serious engine work.
Jeff
74 911, #3
Old 04-08-2013, 11:26 AM
