front ride height adj question
Did a couple of searches, but didn't see anything.
Does someone know, roughly, how much 1 turn of the front torsion bar adjusting screw changes the ride height at the fender lip. Not exact, just a rule of thumb guideline.
Thanks,
Mike
1986 3.2 to 3.4 conversion
Old 04-08-2013, 01:03 PM
Mo money = mo parts
My experience is not a lot. I would guess 1/8th or so.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 04-08-2013, 01:07 PM
r_towle's Avatar
I use a block of wood and place it right under the rear of the bar at the adjuster...
not right under the adjuster, but next to it.
then lower both sides to the block of wood.
Its a lot easier than getting up and down measuring.
Remember a few things though
Car will sit differently with a single driver so if you are doing this for racing, put your weight in the seat (a helper or bags of sand)
Once you get to the height you are seeking, you need to align the car because you just changed the front end geometry.
Last point I would make is that too much rack (front lower than that back) in these cars is actually dangerous.
rich
Old 04-08-2013, 01:12 PM
Go-Kart Mozart
JAR0023's Avatar
I have it written down but can't seem to produce the notebook at the moment. Going from memory I think it's 1 turn equals approx 1/4" of adjustment. I would think torsion bar size and weight of the car would make each case a little different. Don't forget to settle the car after each adjustment. -J
Old 04-08-2013, 02:02 PM
Send a message via Skype™ to Porboynz
On my lightweight 1972 911 2 full turns was close to 3/4 inch lift to get the car back up to legal height, I used to wind on 2 turns to drive on the road then unwind 2 turns for the track. Adjusting the rear each time was a bit more labour intensive....
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 04-09-2013, 12:22 AM
RETIRED
Joe Bob's Avatar
Be advised that adjustment will change weight settings for balance and alignment.
2012 ML350 3.0 Turbo Diesel
Old 04-09-2013, 07:11 AM
Thanks guys. Goes for corner balance and alignment next week, after the full polybronze treatment. I want to get my ride height where it needs to be before that. Hoping to minimize the 'turn the screw, crawl out, drive a bit, crawl under and repeat', by getting a handle on anount of change each turn brings.
Old 04-09-2013, 09:45 AM
Undocumented User
McLaren-TAG's Avatar
I think you've got a catch 22 going on here since getting the corner balance means raising or lowering the corners to get it balanced, so whatever you change the ride height to now will undoubtedly change when you do the corner balance.
Old 04-09-2013, 09:57 AM
RETIRED
Joe Bob's Avatar
I would suggest discussing the ride height with the tech that does the CB and alignment. You're wasting your time unless you are just doing it to get an idea of how it looks.
BTW going real low is limited by bump steer, bump stops and tire specs.
Old 04-09-2013, 10:01 AM
Understood, but there needs to be a starting point.
Old 04-09-2013, 10:04 AM
muck-raker
kidrock's Avatar
not to be a thread thief, but I've seen a few different opinions on which direction the bolts must be turned in order to lower/raise the front end.
Lefty/lower, righty/raise?? Or not??
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-09-2013, 10:23 AM
RETIRED
Joe Bob's Avatar
You are aware that the rear requires re-indexing of the torsion bars unless you have adjustable spring plates, right?
Old 04-09-2013, 10:32 AM
Yes, and yes I do.
Not going real low. There is a min height I need to get in my driveway, which is a bit higher than I would like for track, but oh well.
Old 04-09-2013, 11:49 AM
Undocumented User
Then why are you compromising the ride height on the P car? Get a sledgehammer to that driveway.
Old 04-09-2013, 01:15 PM
Ah, if it were so simple. It's the incline (steep), not the curb - there isn't one. Great view though.
Old 04-10-2013, 08:26 AM
