El Duderino
tirwin's Avatar
Question Lloyd's floormats to use with RS carpets? Please post pics if you can.
I want to order new floor mats for my '83 to protect the new RS carpet set with Rennline footboards I installed. I don't want to get mats that cover the footboards as that would defeat the purpose. Lloyd's makes some rubber mats that look good but I can't tell from the website what the pattern really looks like. In fact there is a big disclaimer that says the pattern shown is general and may not be specific to what you actually order.
Does anyone know if there is a particular model year (like early '70s) that would work? If anyone has any pics that would be a huge help. There doesn't appear to be an RS option. I see Lloyd has a custom option but I'd rather not go that route if possible.
Thanks in advance!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-08-2013, 09:30 AM
I'm interested in doing the same thing. I'm in the process of installing an RS carpet. I purchased the Rennline footboards and like the look of them exposed, problem is the new lloyd mats I have which are very nice cover them up. I hate to cut them, but think I might have to in order to get the look I want. I was wondering if I made a small cut in the lloyd mat where the footboard bolts down I might be able to run the mats right up underneath? I'm interested to hear/see what other have done. Thanks
Old 04-09-2013, 05:15 AM
El Duderino
tirwin's Avatar
Here's what I did. For the carpets (not the mats) I notched a hole in them where the bracket goes through. Since I had two additional layers - 1/4" CCF and MLV - it made the thickness a problem to begin with. I couldn't get enough thread depth. So I went to a local store that specializes in fasteners and I found a coupling nut. I am away from home for a few days, otherwise I would take a picture. You could try something similar. My problem is that the thickness is already an issue and I want something that will protect the new carpet that can be taken out and cleaned. If you do go this route, use an Xacto knife with a fresh blade. Measure twice and cut once.
Old 04-09-2013, 08:22 AM
