Breeang's Avatar
Unhappy Flat-bed ride home
Oh Rats!
I have just got my '77 Targa back on the road after a long period of it being a hobby/garage ornament. Monday it was running well but still a little rough so I added a bottle of Techron fuel injector cleaner to the tank of fresh gas. (I had previously drained the old fuel from the tank). On Tuesday it was running rougher and then yesterday 3 miles from the house an almost complete loss of power. It starts and idles but it's very rough and there is almost no throttle response, I can't get above 1500 rpm and there is not enough power to even move. Thanks to AAA it is now safely back in my garage.
I assume that something has stuck in its throat. What would be a good sequence of items for me to start checking? I intend to pull the injectors and soak them in acetone and install a new fuel filter. Then pull the plugs and check them. What would be the next sequence of checks as I move further into the fuel system?
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 04-11-2013, 07:10 AM
Banned
Check your fuel filters, tank filter and fuel pump. I had a kink in my fuel line once, after a new fuel pump install. I installed it in the front.
A few miles is all I got out of what was in the lines.
From the tank to the engine is enough fuel to get you a few miles. Maybe your tank filter is clogged.
Old 04-11-2013, 07:27 AM
Norm Faustino's Avatar
I just discovered while rebuilding mine that if you dont use thick walled high quality fuel line it WILL kink and I immediately pitched that cheap **** and ordered the good stuff that won't collapse. Definitely, as Dipso said, check your fuel lines first. Since you just had major maintenance done it is likely something that is not sitting right. ESPECIALLY since it starts and idles but wont power up. Sounds to me like a fuel starvation issue.
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 04-11-2013, 07:34 AM
RETIRED
Joe Bob's Avatar
Assuming it still has CIS it's all about fuel pressure. Buy or borrow a set of gauges. Diagnose from there.
2012 ML350 3.0 Turbo Diesel
Old 04-11-2013, 08:02 AM
Breeang's Avatar
Yup still CIS .Good advice all around thankyou.
1st step is already taken -I have warned the wife about a stinky garage this weekend.
Old 04-11-2013, 09:44 AM
Senior Member
Jdub's Avatar
You have freed up a bunch of gunk that has clogged your fuel lines. Your R&R on the gas filter(s) is right on. Try that and see what happens before you start getting in deep.
Sidenote: When my Targa was flatbedded after the CV joint exploded I felt so alone, so exposed - at which point a woman came by and said "I LOVE your little sports car!". I just didn't know what to think!
'78 Targa in Minerva Blue
Old 04-11-2013, 09:47 AM
[QUOTE=Jdub;7380691]You have freed up a bunch of gunk that has clogged your fuel lines. Your R&R on the gas filter(s) is right on. Try that and see what happens before you start getting in deep.
What he said! That is the exact sympton of a clogging up fuel filter. It still passes a small amount of fuel, but not enough to keep running with any acceleration. Replace the big fuel filter next to engine first. Bet it fixes your problem.
Had it happen to me in the same way!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 04-11-2013, 10:24 AM
83 Targa
I am in a similar situation where I am half way through a tank of gas with Techron. All is well excpet the loud buzz from the FP. All the threads say the FP could be dying, so I ordered a pump and filter. Is a pump back flush an option?
Did not mean to hijack the thread , but this Techron stuff seems effective in moving crud around, and its too bad because my initial results seemed promising.
Old 04-11-2013, 11:06 AM
RETIRED
Joe Bob's Avatar
Techron should be used on a regular basis.....less impact when it does it's job.
Old 04-11-2013, 12:38 PM
Flatbed trip #1: Me sad and angry and embarrassed and pissed off and all that.
Flatbed trip #2: Me laughing and waving at the neighbors as the car is dropped off.
I figure anything less than one trip a year on the flatbed is doing good, I'd rather drop the $100 now than sit in a parking lot for 4 hours poking away at a dead engine.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-12-2013, 06:59 AM
