Wer bremst verliert
JohnJL's Avatar
Trouble removing fenders/wings
I'm removing and parting out my front fenders, bumpers, etc. I have all the bolts out of the inside of the frunk and inside the wheel well. The fender panel is loose except it seems to be attached still at the bottom near the front of the door. Is there a hidden screw or trick to remove that portion? The fender is in good shape so I dont want to tweak it during removal.
Here's where it seems to still be attached but I dont see any screws or bolts there.
Car is a 1978.
thanks for the help
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-14-2013, 07:23 AM
Tom '74 911's Avatar
Did you get the 2 bolts outside at the top accessed by opening the door?
There are no hidden bolts at the bottom... although I think they may have sprayed undercoating AFTER they installed the fenders, so maybe you missed one? Or maybe the undercoating is acting like glue and just needs to be sliced?
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 04-14-2013, 08:31 AM
E Sully's Avatar
My fender had a small tack weld at the bottom.
Ed
1973.5 T
Old 04-14-2013, 12:26 PM
Wer bremst verliert
JohnJL's Avatar
Yeah, I got the two up top inside the door jamb. It seems like its just the bottom.
Ed, yours was tacked?
Old 04-14-2013, 12:43 PM
Wer bremst verliert
JohnJL's Avatar
Came off after some gentle manouvering. The PO's paint job has glued things in place. The headlights were stuck in. I dont know what his plan was if the headlight needed replacement.
Old 04-14-2013, 07:15 PM
id say the upper two on the door jamb. my issue was 30 years of caked on crud and spray on under coating.
Ryan- Sad day when my 83 911 left me
Old 04-15-2013, 06:23 AM
