Less brakes, more gas!
euro911sc's Avatar
Thumbs up SS Brake Lines: Interesting White Paper
I was looking for some info on SS lines and ran accross this white paper:
http://www.centricparts.com/files/technical%20guides/stainless-steel-brake-lines.pdf
Thought it might be interesting for some. Only 2 pages so no big deal.
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-12-2013, 06:50 AM
El Duderino
tirwin's Avatar
Thanks for posting. The PO of my SC had bought a set of SS lines and never installed them. I was thinking the next time I change the brake fluid I might put them on. But after reading the recent debate now I'm not so sure. Gotta do some more reading...
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-12-2013, 08:38 AM
Air Cooled
Craig_D's Avatar
Good read! Thanks for sharing.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 04-12-2013, 10:04 AM
závodník 'X'
intakexhaust's Avatar
Thank you and well worth the read.
Years back I had a teflon / stainless braided line from a well known aftermarket supplier going bad. Odd fray near the fitting coupler with no movement or rubbing. Wasn't leaking but could only surmise it from road debris hit. If the vehicle would have had the OEM polymer probably would have been fine.
Interesting:
If a manufacturer claims their SS lines are “DOT compliant”, it means that their SS lines have passed all FMVSS106 requirements, and they have submitted the test data to the government for official certification. This does not mean they are acceptable for use on your car, but it does mean they pass the government minimum standards.
Another term you may hear in this context is “DOT approved.” However, the DOT is not in the business of actually approving or disproving compliance – they don't typically run any tests on aftermarket components themselves. Under these circumstances, one can only surmise that these manufacturers are trying to state that their lines are actually “DOT compliant”, but it never hurts to ask before you buy.
Old 04-12-2013, 10:41 AM
You should keep researching.
When I looked a few years ago, I found information that "DOT compliant" SS lines actually use fittings mandated for rubber hoses - because the fittings are stipulated in the DOT spec. These are not, in fact, ideal for SS lines - as they're designed/intended for rubber hoses. SS line manufacturers lobbied for them to be able to use hose supports - otherwise, those fittings, used incorrectly on SS lines per DOT regs, wouldn't pass the vibration test mandated by the DOT.
So "DOT compliant" may actually be inferior in practise - by design. Like "DOT compliant" sealed-beam headlights (with the mandated "scatter", so you can read road signs on unlit roads, ha!), when everyone else was enjoying halogen H4's since 1971...
That's without even getting into incorrect fittings, inferior material/assembly and lines that blow off the fittings when you're trying to bleed the brakes. Plenty of horror stories about that with cheap aftermarket lines too - although good quality ones shouldn't do that.
And if you use correctly designed and constructed SS lines? What's your legal position if you're in a horrendous accident through no fault of your own - and the crash investigator/insurance assessor discovers non-OEM, non-DOT brake lines fitted to your car?
Correctly designed/constructed and installed SS lines may be superior to rubber hoses. Although I doubt you'll notice a difference, personally - although you may be able to measure it on a test rig.
But then you encounter the difficulties of inspecting these lines, on a street vehicle (racers just change these out with their drivetrains, heh). And I can tell you from experience that they'll wear through anything they touch if you let them move at all.
'77 S with '78 930 power and a few other things.
Old 04-12-2013, 03:10 PM
theclaw's Avatar
The fine print at the bottom of the paper.
Stoptech is the performance engineering and manufacturing division of Centric Parts. It is the leader in Balanced Brake Upgrades for production cars and has three patents in basic brake technology and one other pending. With a worldwide network of resellers, StopTech’s product line includes Balanced Brake Upgrades for approximately 450 applications featuring StopTech’s own six-, four- and two-piston calipers, two-piece AeroRotor Direct Replacement Kits, braided stainless steel brake lines and slotted and drilled original-dimension rotors. StopTech also stocks a wide range of performance brake pads. The company’s website, StopTech, is a clearinghouse of performance brake information, and provides details on StopTech products.
It's marketing.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 04-12-2013, 07:24 PM
Racer
winders's Avatar
Originally Posted by theclaw View Post
It's marketing.
Of course it is. That doesn't automatically make the information incorrect. In fact, since they publishing the information, it is in their best interest to make sure it is accurate and factual. Otherwise, they could get in legal trouble or damage their reputation.
I read nothing in the article that jumps out as being factually incorrect.
Scott
Old 04-12-2013, 07:53 PM
theclaw's Avatar
Scott
You're absolutely correct. I should of elaborated. Third party info always carries a little more weight if it's really an unbiased analysis. When the source also sells the stuff I consider it marketing. Could be positively accurate, still they are giving you a pitch. I do it all the time!
'67 MB 250SL
Old 04-13-2013, 04:22 AM
I use braided stainless flex lines all the time but don't purchase DOT type. I make them up myself. They are cheaper and better.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 04-13-2013, 07:54 AM
GrantG's Avatar
Does this require any special tools (like crimper)? Where do you purchase the supplies?
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 04-13-2013, 11:31 AM
the fine print at the bottom of the paper.
stoptech is the performance engineering and manufacturing division of centric parts. It is the leader in balanced brake upgrades for production cars and has three patents in basic brake technology and one other pending. With a worldwide network of resellers, stoptech’s product line includes balanced brake upgrades for approximately 450 applications featuring stoptech’s own six-, four- and two-piston calipers, two-piece aerorotor direct replacement kits, braided stainless steel brake lines and slotted and drilled original-dimension rotors. Stoptech also stocks a wide range of performance brake pads. The company’s website, stoptech, is a clearinghouse of performance brake information, and provides details on stoptech products.
it's marketing.
+1
Sold: 1989 3.2 coupe, 112k miles
Old 04-13-2013, 04:07 PM
No special tools required. Use AN-3 braided stainless hose and the specified fittings. Earls or Aeroquip or Goodridge brands come to mind. I generally use Aeroquip. I suspect you'll need a couple metric to AN-3 adapters - they may even make a metric banjo fitting for the calipers.
A quick search shows Earls here:
AN Speed-Flex PTFE Hose | ANplumbing.com
Here are the appropriate steel fittings:
AN Speed Seal Steel Hose Ends | ANplumbing.com
To cut the hose, wrap tape around it then cut it with a cutting wheel. Lubricate the fittings (after removing the tape!) and use a new "brass olive" every time. The fittings are re-useable.
Use AN-3 hose for brakes and AN-4 hose for hydraulic clutch.
Old 04-13-2013, 05:08 PM
GrantG's Avatar
Thanks!
Old 04-14-2013, 06:58 PM
I have StopTech braided lines on my car. Other issues aside, I like that they use a clear polymer tubing over the braid which protects the braid, keeps the dirt out from between the braid and teflon line, and still allows visual inspection.
1986 3.2 to 3.4 conversion
Old 04-15-2013, 08:41 AM
It took only 49 years!
mclmk8d's Avatar
I haven't been able to find lines for my 87. What is the Stoptech part number for your lines and where did you buy them?
Serge: In the heart of Philly!
Daisy - 1972 911T 2.7L Light Yellow
Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD
Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
Old 04-15-2013, 11:41 AM
I called Stoptech directly, but that was a few years ago. I don't have part numbers for you. The site seems to be down at the moment.
Old 04-16-2013, 06:37 AM
One of the very first things I did on my car was swap out the original lines out with the stainless braided kit from Pelican. Could not feel a difference and I don't buy the statement that the stainless braid is so tightly applied or woven that it restricts expansion of the inner Teflon hose.
However, it is nice to know the lines have been addressed from a maintenance standpoint.
Ken
1986 930 2016 R1200RS
Old 04-16-2013, 08:34 AM
theclaw's Avatar
Ditto.
'67 MB 250SL
Old 04-16-2013, 03:53 PM
DCinVA's Avatar
The stainless lines are nice, and it is important to replace older brake lines. As the rubber ages it gets hard and can crack or break. I typically test old lines by bending them, and looking for surface cracks in the rubber. If they show cracking in the rubber, replace them.
So, having said that, how do you check the condition of a rubber line that has been wrapped with stainless braid? Can you see the rubber thru the braid?
Dave
2014 Cayman S (Awesome car!)
1991 911 Carerra (Semi Refined fun)
1986 911 Carrerra (Raw fun) sold
2001 Boxster S (Refined fun) sold
Old 04-17-2013, 01:37 AM
Senior Advisor
James Brown's Avatar
easy, cut it in half on a band saw. all kidding aside, just remember to change out brake lines every few years and you should be good, bradded or stock
08 Cayenne Turbo
Old 04-17-2013, 03:10 AM
