DME relay question
I have the seats out of my '86 911 and noticed the DME relay, which works just fine, no problems, is marked 12V 15A but my spare says 12V 30A. Why the difference in Amps? The one now installed is probably original, and the spare is the correct part number etc, bought from pelican made by K.A.E.
Also, can this DME be changed on the fly with seat in place? Looks tricky. Has
anyone changed this on the road?
Old 04-19-2013, 10:41 AM
Undocumented User
McLaren-TAG's Avatar
I'm so good, I can change mine with my toes while the car is still rolling.
As far as the DME amp number, It may just be the rating for the relay. I've got a KAE and a spare URO both say 30A.
Old 04-19-2013, 10:53 AM
In my current issue I don't even screw it in
I let it hang with a zip tie .
Old 04-19-2013, 10:58 AM
dshepp806's Avatar
Just the contact rating.....and yes: 30 Amp is healthier (beefier) than a 15 Amp relay!!!
Easy to change with seat in situ.....you just need to be sure you've the correct tools to make it an easy go.
Geeze,..I keep two of 'em nearby!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-19-2013, 11:10 AM
RETIRED
Joe Bob's Avatar
URO relays need to be pre float tested......
2012 ML350 3.0 Turbo Diesel
Old 04-19-2013, 11:18 AM
muck-raker
kidrock's Avatar
I've used KAE with no issues (knock on wood). Slide the seat back and loosen the 10mm nut and you're off and running.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-19-2013, 11:30 AM
What do you mean by URO?? I get the impression that they are inferior.??
Didn't mean change DME on the fly, I meant stopped, parked and immobile. Guess I'll pratice while the seat is out.
Old 04-19-2013, 11:33 AM
Must be "Unreliable replacement order"
Old 04-19-2013, 12:34 PM
E Sully's Avatar
I would be a little concerned with a 15A relay, considering it feeds a fuel pump fused at 25A.
Ed
1973.5 T
Old 04-19-2013, 01:00 PM
