-   -   I want real A/C on my 87 3.2 - please share your upgraded system installs & reviews (http://forums.pelicanparts.com/porsche-911-technical-forum/745690-i-want-real-c-my-87-3-2-please-share-your-upgraded-system-installs-reviews.html)
kuehl 05-11-2013 10:37 AM
Originally Posted by wwest (Post 7435996)
The EPA has now comfirmed that the original "non-barrier" hoses will work just fine when converting to the new refrigerant. Needless expense, especially if you follow Kuehl's suggestion below of using a binary pressure switch to prevent overpressuring the system.
EPA quote "A least-cost retrofit, however, may not provide a satisfactory solution for certain vehicles." Meaning = on cars with 40 feet of non barrier hose as compared to a Lexus. Another "EPA" quote "In most cases, the R-12 system hoses will perform well, provided they are in good condition. Cracked or damaged hoses should always be replaced with barrier hoses." So, you gotta wonder, logically, if the EPA 'thinks' non barrier hoses will work just fine ... then why do they suggest replacing old hoses with 'barrier hoses'.
So are DuPont, Goodyear, Parker and many others during the past 20 years have been in collusion?
Quote from Dupont:
"Elastomeric hoses are used in mobile air-conditioning systems and for transferring HFC-134a in other applications. The permeation rates of HFC-134a
and CFC-12 through several automotive A/C hoses were measured as a guide to hose selection The studies were run at 80°C (176°F) with an initial
80 vol % liquid loading of HFC-134a in 76-cm (30-in) lengths of 15.9-mm (5/8-in) inside diameter automotive air-conditioning hose. Hose construction
and permeation rates are summarized in Table 18. Based on these tests, hoses lined with nylon, as well as those made of Hypalon
® 48, appear to be suitable for use with HFC-134a. Note, however, that these rate measurements provide a comparison of the vari-
ous hoses at a single temperature and should not be used as an indication of actual permeation losses from an operating system. "
Dupont Study
According to several certified A/C technicians I discussed this matter with there is really no need to replace the dryer/drier provided the system is FULLY evacuated before refilling.
Ask the 'certified' buddies what is the purpose of a drier. What are the differences in desiccant types and how are the affected by the different refrigerants and oils. What happens to the desiccant after 20 years of absorbing moisture. How long a desiccant bag will last. What happens when you allow sludge oil in the drier to mix with fresh oil and what affect it has on the compressor and TEV.
He means to say a deposit of black rubber on the engine lid above the compressor drive pulley/clutch. But that can also be a sign of V-belt "shredding".
No. "He" :) means the black line that is there because oil blew past the compressor nose seal and "IT" attracted what ever.
Or simply wait to see if the system holds the new refrigerant, INEXPENSIVE refrigerant vs labor cost looking for problems that are unlikely to exist.
No. The 86-89 models have a copper manifold bonded to aluminum tubes... and the bond does not last forever and it leaks. Travel over the to the Renn or PP 928 forums and ask our fellow friends about their evaporator issues on 86+ years.
Yes "some" upgrades, spoken as a true SNAKE OIL salesman. Just adding a fender mounted condensor/fan(***) will more than suffice for bringing the system up to a more reasonable, satisfactory, quick cabin cooldown period.
WWest, here you go again. One day you say cars need better condensers and evaporators and other days your choking on your own snake oil thing. Flip-Flop-Flip-Flop.
fintstone 05-11-2013 11:52 AM
If you were happy with the factory air and it worked fine a couple if years ago...as long as you dont see any indication of failure, jjust have it serviced with R12...just don't expect it to be ice cold.
SilberUrS6 05-11-2013 01:44 PM
Originally Posted by 87CaliforniaCab (Post 7434975)
Please excuse a new member and older purchaser of the Bird, but this looks to be the best thread to post relative questions.
Call Griffiths and talk to Charlie. DO NOT listen to wwest in this forum. He obviously has some sort of axe to grind,so he threadcraps every single AC post to try and get his digs in on Griff.
Don't take Griff's word for it - talk to the guys at Rennaire and Retroaire. They will all tell you you stuff that will help in your quest for good AC in these cars. It is possible to get good AC, you just have to spend money.
teachkenpo 05-11-2013 02:40 PM
subscribed
kuehl 05-12-2013 09:54 AM
What the EPA meant to say was:
If you have a typical 1980+ front engine car and most of the ac components are located in one area (the front of the car). And assume the flexible hose lines, that were made of non barrier hose, were the connections to the compressor (from evaporator to compressor inlet, compressor outlet to condenser). And, the other lines were fabricated of aluminum tubing (typical for 80+ years and onward), most likely you have about 6-10 feet at most of “rubber” non barrier lines.
Then the rate of leakage “may” not be that significant for the typical car owner who’s jalopy/junker is probably out of warranty (aka 5+ plus year old car); meaning a car owner who does not want to put a lot of bucks to convert to R134 in an old car. So ‘we’ (the EPA) have gotten a lot of phone calls and letters from taxpayers whom are pissed off at us for requiring you to buy new barrier hoses.
So we are going to change our (the EPA) position on permeation (leakage of refrigerant through old non barrier hoses) because we can justify the change based on rumors and phone calls and letters we have gotten from automotive technicians whom also have griped and complained that their customers don’t want to spend the money. So we are going to ignore all the test data we previously had and go with the flow!
Leakage rates of non barrier (stock) hoses vs. barrier hoses
In the study reported by Dupont (and hose mfg's have post like studies) they had 30" sections of 5/8" ID diameter ... various types of barrier hose and non barrier hose. They filled the hose to 80% of its maximum volume with liquid refrigerants (R12 and R134a). They heated it to 176F. They don’t tell us the pressure but we might guess it was 380 psi for R134 and 333 for R12 depending upon your interpretation of temperature/pressure charts (typical of the high side on either an overcharged system or a very hot day, most systems don’t run near this psi range; I’d suggest 225-250 psi is running average while 100 psi is the average “resting” psi when the system is off ). They noted annual leakage rates forecasted to be: for R12 refrigerants to be 1.5 pounds per year with non barrier hoses and .3 pounds per year with barrier hoses; for R134a it was 1.8 pounds per year for non barrier and .2 pounds per year with barrier hoses. Frankly there is a great loss with non barrier hoses regardless of the type refrigerant you use. And logically, the more you use your AC system the greater your losses are, there is a big difference in AC "on" time for someone up in Seattle vs. someone in Houston and likely the same is differences for a 'weekend' driver vs a 'daily' driver.
EPA Flip Flops
The EPA thinks that is not significant today with their flip flop position on barrier vs. non barrier. The EPA one day says coal ash is a hazard and next day it is not a hazard. The EPA flips and flops on lead paint removal methods and shale oil fracking. So Frack the EPA.
The FACTS:
The EPA is addressing vehicles that typically have 6-10 feet of estimated hose in the car with an engine in the front.
A 911 rear engine car is totally different world.
A stock 911 two condenser system has 40 linear feet of hose while a 930 has 43 linear feet.
The Dupont study used 30 inches 5/8" ID hose, 9.2 cubic inches, 60 square surface inches.
Assuming average front engine car estimate of hose is 21 cubic inches, 178 square surface inches.
The 911 and 930 does not use 5/8", rather it uses 5/16", 13/32" and ½" diameter hoses:
or 66 cubic inches, 621 square surface inches.
So the difference between the average front engine car vs. a 911 is:
Front engine car = 21 cubic inches, 178 square surface inches
911 = 66 cubic inches, 621 square surface inches.
The 911 has 214% increase in cubic volume and a 249% increase in hose surface area (the later is more important in terms of permeation).
So a rear engine 911 or 930 can see an annual leakage rate that is 3 to 3.5 times greater than a typical front engine car.
And, the leakage rate per year does not get "better because of oil absorption" in the ID of the old rubber hose. It gets worse. Believe me-you.
Read about barrier hoses in The Mr. Ice Project
BrakeL8 05-12-2013 01:42 PM
Nm
BrakeL8 05-12-2013 01:45 PM
Sorry kid hit the iPhone buttons while I was reading. No message.
Kidasters 05-12-2013 06:30 PM
You've heard lots of opinions.
Here are some facts.
I have an 84 Targa. I spent a bunch of money on A/C, because I live in a hot state.
I did the complete rennaire system, with the Kuehl serpentine front condenser. If I could do it over again, I'd order the entire system from Kuehl.
With the Kuehl front condenser, Kuehl super evaporator fan, new directional vent (instead of the "bowtie" on the lower vent), new custom aluminum rear condenser, all new hoses, Rennaire Pro Cooler, new compressor and charged with 134, my A/C will keep me comfortable in Texas in the summer. I'm going to tint the windows at some point, since that rear window is like a greenhouse. But - it's all still better than the stock system.
Want really good A/C in a 911? Buy a 993. It's the only air cooled engine car where they finally got it right.
Otherwise, be prepared to spend some major $$ for cold air.
wwest 05-12-2013 09:48 PM
Of course it is, but just "still better"...For the kind of dough you laid out you should have an EXTRAORDINARY A/C system.
Rennaire ProCooler...
A fool and his money are soon parted.
You could have started, and ended, with a trinary pressure sensor and a fender mounted condensor/fan combination and been well ahead of the game on all counts.
87CaliforniaCab 05-13-2013 07:32 AM
87 3.2 AC recharge
Gents - THANKS for your thoughts and for not tearing me up for the low miles :) but the car will be around after the next ice age. Will consider all the thoughts and NO testing of A/C system or disconnect it until I know all is well. I don't use A/C much and try to avoid SLAB (freeway) driving (too many rocks, trucks, SUVs/minivans) and take the Giant Killer out on open winding roads. I don't listen to the radio or have a drink next to me when driving. I have seen the black oil line as noted, years ago, under the engine lid - but that's a thing of the past. The plastic rear window is immaculate - I burnish this with a plastic polish after first carefully removing dirt/dust every few months with a wet towel. Just installed a new ALARM and the boneheads did not clean or unzip the window before dropping the roof and scratched the plastic - they denied but I was able to polish out most scratches. They used connectors in the engine area that lack rubber boots, so I've used electrical tape in a few locations. I wish to keep the beast as stock as possible. Other benefits: look around at a light, everyone is gawking and I get to go first at an intersection even if I'm there last. I believe the DMV has a supplemental regulation that CARRERAS HAVE THE RIGHT OF WAY. Let's hope Rennsport V is in CA, again. Thanks....http://forums.pelicanparts.com/uploa...1368455479.jpg
friendly 05-13-2013 10:05 AM
Just used the "ignore list" for my very first time. Can't wait for WWest to post again...
Thanks to the other posters, I've learned a lot here!
wwest 05-13-2013 10:19 AM
How's this?
SilberUrS6 05-13-2013 10:59 AM
Yup. Simple and easy.
I figure that there are some folks in the world that serve as a warning to others. In the aircooled Porsche A/C world, wwest serves that function.
rgoodrich 05-17-2013 06:44 PM
Short version:Griffeth Kuehl system. Save your money and buy the best. I saved for a year, and I have a refrigerator for a Porsche. Charlie's system is just that: Components well built and well engineered. I know a lot of people like to tinker, but the Kuehl components work together to produce ice cold air. None of this "next year I'm gonna..." My 84 Carrera on the highway at 3/4 fan and 60 mph at 110 AZ degrees.Vent Temps were at 34 degrees. And that was with the compressor control only at 6:00. What else do you need? High output blower fan and extra vents. I got everything he has, and I'm ecstatic that I'll be able to drive my car year round. If anybody has any questions, PM me.
Happy almost summer to you all!
GH85Carrera 05-17-2013 08:08 PM
I have the same basic system. It works like just like wanted. It still does many years later. No recharge needed.
SilberUrS6 05-17-2013 08:11 PM
You heard wwest, that just isn't possible. LIES, all lies!
m110 05-17-2013 09:11 PM
What I did, 88, black on black, live in LA:
Griffiths barrier hose kit, new front condensor, new evaporator, new drier, rebuilt stock compressor from Griffiths (which was actually a new part), stock rear condensor cleaned with mineral spirits, hi/lo switch.
Charged with R12. I couldn't find any real reason why R134 would be better.
Added the center vent kit and modified the fan with a variable speed switch (all from Griffiths).
The rear coupe glass and rear sides are tinted.
The windshield is coated with 3M crystalline which is a clear tint but blocks infra-red heat.
Front condensor fan lubed, fuse added, fluxing.
Seats have wool fabric centers.
I put a sunshade up if parking in the sun but generally park covered.
Engine aux front Carrera oil cooler with fan and thermostat working well.
Overall it works well. In LA traffic at 105 it starts to strain but that's rare. It's not a Lexus. My goals are not to sweat and not to die.
The only things I would consider are adding a decklid fan (yes, I know) for sitting at a standstill at idle. This is rare so haven't seen the need. Any motion and condensor function seems fine.
I will likely replace the AC blower with the new high volume one...mostly for sound reasons...mine is just loud.
The only other thing would be a crotch blower fan on my recaros....there is a mounting point and it's cool. As Sellers said in The Party: "Oh, I'm on a diet but what da hell"
wwest 05-18-2013 09:49 AM
Please stop miss-quoting me, I have never said these solutions do not work, they work well, assuming you have dug deep enough into your pockets.
It remains my firm belief that you could begin, and END, by adding one of the aftermarket fender mounted condensor/fans and get perfecly adequate A/C capability. You can overcome the non-barrier hose leakage problem at the same time via the use of a trinary pressure switch to run the same fan WHENEVER (ignition/engine on or off)the pressure dictates.
wwest 05-18-2013 09:53 AM
Should you add the decklid fan, or fans, may I suggest you convert the hi/low pressure switch to the trinary one? Then use the new function to run the decklid fan(s) connected directly, fused, to the battery.
Tremelune 05-18-2013 11:32 AM
As long as we can all agree that Mormonism is the one true religion, this cabin temperature stuff will work itself out in time.
I guess I'll just drive my other car on hot days...
ghiaholic 05-20-2013 05:41 PM
Here's the upgrade that was installed on my car by a previous owner. There is a sticker on the blower that indicates it was upgraded to 134a in 2003, but I have no record of what specifically was done with hoses etc.
Of the changes I can see, they added a vent under the dash to replace the bowtie vent.
http://forums.pelicanparts.com/uploa...1369096599.jpg
They also wired in a second condenser blower at the front. Unfortunately by doing this, the encroached on the spare tire well, so right now I run without a spare tire in the trunk.
http://forums.pelicanparts.com/uploa...1369096150.jpg
I charged the system with a DIY 12a recharge kit from my local auto parts store.
It was about 70 degrees outside when I did the test:
http://forums.pelicanparts.com/uploa...1369096389.jpg
I was getting around 50 degrees with the probe in the vent.
http://forums.pelicanparts.com/uploa...1369096498.jpg
The system seems to keep the car the coolest if I run with the sunroof closed and the windows just slightly cracked open.
kuehl 05-20-2013 05:49 PM
ghiaholic
No comment on the changes in vents or the front cond blower motors,
but i'd say your not as cold as you should be based on your vent temps
and ambient. Have someone test the pressures and temps.
wwest 05-20-2013 07:40 PM
Originally Posted by kuehl (Post 7452350)
ghiaholic
First, it seems to me that leaving the center vent totally open back at the firewall would provide the least restrictive system air outflow.
Second, since my own opinion of the shortcoming of the Porsche A/C is the lack of sufficient refrigerant condensing capacity I would say the second front condensor cooling blower was definitely a step in the right direction.
Hmmmm...lots of miles accured on several Porsche's and NEVER had to inflate that spare.
and ambient.
Absent knowing the blower speed setting it's impossible for you to make that "call"..
Why?
kuehl 05-21-2013 04:37 AM
ghiaholic
If you have a service gauge set connect them up.
Start the engine, leave the engine deck lid 'gently' resting on the service hoses (you don't want the lid lock to engage, quite a bugger to fix things after that happens).
Have all your windows up, fresh air vents closed (top levers to the left), heat off (levers down), sunroof closed. Turn the thermostat knob on the left fully clockwise to max cold, turn the fan speed switch on the right to its 2nd speed. Have your thermometer in the center vent above the radio. With the engine idling, the front condenser blower motor(s) should both be running and compressor clutch engaged.
Let the engine idle for 5 minutes or so and advise the following at idle:
Low side pressure,
High side pressure,
Vent temperature,
Outside air temperature around the car.
Write these observations down.
If you have a digital electronic thermometer compare it to the analog unit you are using in the freezer and outside and advise if there is a difference between the 2.
Let us know. If you need further help just drop me a PM.
Griff
wwest 05-21-2013 08:57 AM
Originally Posted by kuehl (Post 7453000)
ghiaholic
Let the engine idle for 5 minutes or so (while being sure the compressor clutch remains engaged) and advise the following at idle:
Low side pressure,
High side pressure,
Vent temperature,
Kuehl needs to know the OAT to quanify the system pressures but you should also advise him of the IAT (Interior Air Temperature), air temperature going into the evaporator, should it differ somewhat from OAT.
Griff
With the engine idling knowing the OAT may not really suffice due to engine's radient heating of the rear lid condensor. So should you have an IR guage the sensed temperature of the rear lid condensor and the front lip condensor might be helpful.
The edits seemed appropriate, hope you don't mind....
kuehl 05-21-2013 09:23 AM
LMAO.. Wwest.
if I may remind you of your previous post to the question of your Porsche AC experience: Post 36
"So, how many 911's and 930's have you (Wwest) put AC service gauges on during the past 30 some years? NONE!
Just let the guy do the tests so we can all see what's happening.
wwest 05-21-2013 10:46 AM
Originally Posted by kuehl (Post 7453446)
LMAO.. Wwest.
Again, only an idiot with half a brain would assume that an absence of hands-on experience would prevent a high depth of knowledge regarding these systems.
I don't see you saying my "edits" weren't appropriate....
Why did you write, compose, "The ICE Project" if there is no gain in one's depth of knowledge in reading same absent actaul use of "AC service gauges"
wrinkledpants 05-21-2013 11:00 AM
Wwest - test your kit, or STFU. Seriously - I'm starting to think you genuinely have a man-boner for Kuehl. Every person that hounded me like you hound Kuehl - I have slept with. So, I can't help but think you either have a secret man-crush on Kuehl or you are genuinely a troll. No other person would go through this much effort to NOT prove that their system works unless those two previous statements were true.
Cowboy the **** up and test your kit, admit you love Kuehl, or STFU already.
Nick Triesch 05-21-2013 11:15 AM
I have worked on my stock 85 Carrera A/C for the past few years and now I get 40 degrees at the vents! So my Wife and I went for a ride to Coronado the other day and I noticed even at 40 I was still sweating. The bottom line is this...Our cars have too much glass with a very hot air cooled motor in the rear and too few vents. In other words it is a terrible design and just does not work very well unless you change out the entire unit and replace everything with a different design. I have decided to just drive my car and not worry about the A/C any longer. Just uses more gas!
kuehl 05-21-2013 11:33 AM
More Vents!
78-85 year cars
http://forums.pelicanparts.com/uploa...1369161200.gif
kuehl 05-21-2013 11:34 AM
Yeah Wwest,
Get rid of the crush. My girl can whip your butt! lol.
SilberUrS6 05-21-2013 11:48 AM
LMAO.. "So, how many 911's and 930's have you (Wwest) put AC service gauges on during the past 30 some years? NONE!
That's the great thing about the internet - some guy with zero automotive AC experience can pretend to be an expert. And when confronted about lack of experience, shouts to the world "prove me wrong!"
Wrong on the facts, wrong on the theory, wrong on the physics. But an expert nonetheless.
Nick Triesch 05-21-2013 11:52 AM
OK, I just checked my 85 Carrera owners manual and it says to check your refrigerant once a year because the fluid diminishes gradually during operation. So.......our cars do leak over time!
kuehl 05-21-2013 11:59 AM
Correct Nick. And the shop manual says the same thing.
That's because there is 40 feet on non barrier hose.
Nick Triesch 05-21-2013 12:03 PM
Thank you kuehl
SilberUrS6 05-21-2013 01:24 PM
Now, Griff - you *know* that's just simply untrue.
LOL
WYDBODY1986 05-21-2013 02:14 PM
I have an 86 911 and I live in sunny and extremely muggy South Florida. I have done and tried pretty much all of the recommended mods to my AC to the tune of about $2000.00 over the past few years and when I pull the car out of the garage and the in car temps are around an ambient of 80-90 degrees I can get vent temps of around 35-45 degrees so I know my AC works.
The problem that I have and to some degree I am sure everyone else has is heat soaking in the Florida sun, even with the windows tinted and a sunshade in the front window if the car sits for an hour or two in the sun the interior temps are around 120 degrees easy. Given enough time the car will cool itself down and temps at the vent are 60 degrees almost immediately after I turn the AC on but even with Griffiths upgraded Evap fan motor, which is much better than stock, it still can't move enough air in the cabin to sufficiently cool down the interior in a timely manner.
What have you guys tried to move a higher volume of air in the cabin. I would rather have cool air moving at a higher volume than really cold air that I can't even feel on my face while I am driving!
Nick Triesch 05-21-2013 03:12 PM
I just don't think it's going to happen in an old air cooled car. I bet most 84-89 911 owners A/C does not even work in their cars. Great cars, terrible A/C.
kuehl 05-21-2013 04:34 PM
Here is how you get comfortable AC
mrm930 05-21-2013 04:59 PM
I replaced and currently installing everything new from Griffiths. High quality pieces - can't wait to get it going. Hoses, fans, condensers, fender condensers, drier, switches and under knee pad vents (tri-vent system). Cost was around $3K - will be worth it
