You already did that... You said that legacy systems that included refrigerant pressure relief valves, "fuses" required the addition of a hi/lo pressure switch when converting to R-134a to prevent inadvertent, no system failure, tripping of those relief valves. Seemingly R-12 systems have an expectation of a system failure leading to excess pressures higher than 450 PSI. What might those expectant failures be and what might be the parallel expectant failure for our Porsche's that have no pressure relief valves....? Capillary tube/bulb not properly, fully, inserted into the evaporator core...? Capillary tube/bulb function failure due to loss of internal charge? TXV malajusted or drifted out of tolerance, full restrictive level at 34F, and thus prevents the evaporator core from ever declining to the 28F thermostatic switch "off" setpoint? Continuous demand for 34F vent temperatures, evaporator continously near freezing and with TXV mostly closed. How high might high side pressures get when the compressor runs "open loop" (no pressure level feedback) with those conditions existing continuously for hour after hour..? Close to maximum system component design specifications...??? Now turn off the ignition out in the HOT August Texas sun. Last edited by wwest; 05-19-2013 at 10:26 AM.. |
Banned
Wwest,
We promote the use of our binary low high pressure switch for these reasons: 1) Certain regulations required a switch. 2) If system refrigerant levels run too low the compressor can be damaged do to lack of sufficient refrigerant/oil flow. 3) Excessive high side pressures can blow out the compressor nose seal. Unless you can prove to your peers that your theory of over pressurizing of the system is caused by engine heat, meaning you can provide real data of system pressures A) System turned off, prior to starting engine and running AC B) System running normally C) System turned off, after running engine and AC Everything you continually post on all the threads is simply your own personal theory. The 911/930 system equalizes rather quickly when the engine is turned off; the high side drops and the low side rises. The high side bleeds over to the low side through the TEV (no matter how cold the evaporator was before hand), its just a simple fact based on the construction of the TEV. And this is true for various other types of systems (industrial, commercial, residential), all depending upon the TEV design. So tell us, how many 911 or 930' air conditioning systems have you worked on in the past 30 years? |
Banned
There are a whole bunch of other factors involving our air cooled cars A/C systems. I have found out that even if you get 40 degrees at the vents or even lower temps, you still have terrible A/C in our cars. The reasons for this are not that technical, just really bad design. A tiny little car with a very hot air cooled motor in the rear plus a bunch of glass and two tiny vents in the front and two tiny one at your knees. A/C in our cars for the most part is very crude compared to most all other cars of their time period. I'm Ok with it because I love my car.
R-134a Binary pressure switches open the low side at ~28 PSI, the high side at close to 400 PSI, That's right, 400 PSI! In my meager experience it's the low side pressure sensing that most often cycles the compressor off and on. The extra function in the Trinary pressure switch is most often used to run a condensor (& radiator) cooling fan/blower with high side pressures above 225 PSI but not below 185 PSI. |
Fleabit peanut monkey
Not only bovine feces but cow poop, too
I still like his input. Also, keeps Griff off the golf course.
1981 911SC Targa |
Banned
You are guessing. Guessing just like you have in all the 100's of posts you make here. Quote:
And, most TEV systems don't use a low side switch to cycle the system on and off. Quote:
And, I'd say if you are seeing a 40 psi equalized pressure you are either totally trying to B.S. the forum here or its 30F outside when your checking those pressures Quote:
So, how many 911's and 930's have you put AC service gauges on during the past 30 some years? Wanna put your money on the table? Last edited by kuehl; 06-01-2013 at 08:05 PM.. |
Wwest
Good one!
As do countless worms that have been burned.
1981 911SC Targa |
It's gettin' real in the PP 911 tech forum.
1981 911SC Targa |
Sure. |
Banned
Banned
I have a funny OT story for you. In a foursome, out on a public course, 20 years ago. My pals were pretty lubed up by the 14th, and I hit my second shot on the par-4 into a greenside bunker. Well, I get up there and haul out my wedge, and am walking down into the bunker and stumble, dropping my club. Immediately, they are on me about grounding my club in the bunker. After I pick it up and start shaking it at them to shut the hell up, I bring the club back down to address the ball, and the head hits the lip of the bunker, and the club falls out of my hand, again. OK, by this time, we're all in tears because of how ridiculously funny it all is, and I can't see straight to hit the ball. I take a giant swing, and empty out about half the bunker. The damn ball rolls up to four inches from the cup, and I tap in for par. No, no, no, they all wail, two penalty strokes for grounding your club in the bunker. I still laugh to this day. |
