The exact kind of diode is not very critical. You can try an IN4001 which is pretty common. It is good for 1 amp. I don't know how much current the TPS sinks but sensors should be relatively low current. If you have an ammeter, you can disconnect the TPS ground wire and put the ammeter in between the ground wire and an actual ground surface on the vehicle to see the current. If it's higher than 1 amp, just source the diode to handle the current, as that is the only real specification you will need to meet.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Straight shooter
A diode is a basically a check valve for electronic current. If you're looking to increase ohms of resistance you will need a resistor. Getting real rough you would simply add a resistor (not a diode) of the value difference from 5v to your real world wot reading. Ohms law...
Ohm's law - Wikipedia, the free encyclopedia
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
The OP is trying to go up in voltage, not down, hence the diode suggestion.
Having said that, mmasse, still would urge that you look at a software solution. It should be a pretty trivial exercise. Also, are your tables only based on TPS? Or do they also use MAP? In many cases, TPS only drives acceleration enrichment and the VE table is driven off of MAP. In any case, the tuner you are planning on using should be able to calibrate the TPS in a minute or two. Last suggestion, have you checked with the manufacturer? They might be able to point you to a calibration tool in the software.
Kinsley 1980 SC Targa - MS2, EDIS |
Kinsley,
Thanks for your input. Regarding the software solution, it will not solve the problem in my case. The issue is that I am using a piggy-back Unichip which modifies the base maps on the Motronic. I can modify the value for TPS on the Unichip, but this will not make the Motronic work on the WOT maps. Do you know if the OEM Motronic for the 993 uses the TPS at all in order to trigger the WOT maps. If it is only MAF/MAP based then TPS will not be an issue at all. Thanks again
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 |
Straight shooter
Input is 5 volt as per multimeter, so that not the problem
I also tested a spare TPS and same thing |
