JR911's Avatar
Question Need torque spec for cam oil line bolt.
Hi guys,
I'm installing my new cam oil lines (3.2) from Pelican today but can't find the torque specs for the large "banjo" bolts.
Any help is appreciated!!
Thanks, J.R.
Old 07-27-2002, 12:25 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Sorry I don't have the exact value, but if you tighten the bolt just to the point where you feel it firmly contacting the sealing washers you're right there. Then give it just a tiny tiny bit more of a turn and you're tight. Go for a test drive and then check for leaks.
Kevin L
'86 Carrera "Larry"
Old 07-27-2002, 03:55 PM
