915 shifting
Hi,
I’ve had few manual cars and off course every car manual is different. First 911 with 915 shifter and while all looks tight to me(maybe some wear) this shifter is nothing to brag about. Strokes are long, 5th to 4th kind of jumps on you and seeing one shift this transmission looks like old comuninst worn busses. Am I accurate on this comment or completely off? I know these have their own carisma etc but was wondering if someone can help me with two things: 1. What can be done to make the shifting faster and more enjoyable? 2. Can someone “describe” the 1st to 5th shifting as I have feeling mine not be what’s expected. Note: drove Citroen c4 few years back in Europe and that shifter was smooth as glass, my sisters Honda Civic is pleasure to row, my 335 short shift kit manual was just horrible. My 72 bmw 2002 shifter was pleasure, few examples to mention. Thank you
1974 911 coupe 4 speed Last edited by kavadarci; 05-12-2018 at 08:04 AM.. |
911 carrera 3.2 (1985)
I have installed a new ball cup bushing, shift rod bushing and coupler. Made a lot of difference.
Maybe I can start with refresh of the linkages.
Does anyone know what I need to refresh the 915 linkages? Thank you
1974 911 coupe 4 speed |
Tunnel bushing, ball cup bushing, Coupler bushings.
There are tons of good threads on improving the 915. You’ll be able to find various recipes. |
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=seine |
In order:
1) make sure all bushings from shifter to coupler are good 2) make sure coupler correctly adjusted. The 915 shifter is very sensitive to correct adjustment 3) aftermarket shift kit, e.g. seine or Wevo or etc. this will add centering between gates and make it feel a lot more modern. After all that, the 915 is never going to shift like a Miata or a Honda. Hell, even my Fiat Soider has a more modern-feeling shifter.
'80 SC Targa Avondale, Chicago, IL |
1986 Bosch Icon Wipers coupe. |
I have mine all refreshed with new bushings and we've shifter and I still has its quirks. I once read that slow deliberate shift are best on a 915, count; 1, and, shift. Repeat.
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
They are what they are. You don't shift them fast.
The 915 in my car had been rebuilt at some point before I bought it and all the linkages/bushings refreshed. Shifted very well but now shifts even better with a shift lever extension from Seine Systems. They offer two kinds as shown in the pics (from Seine).
2000 Boxster S and 2016 Audi A6 |
falls to the knob right next to your knee. I've had six 911s with 915 trans and this is the best shifting I have ever experienced with a 915. ______________________ Grant
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Does anyone have the list of the parts needed?
Ooh i love that shift lever extension. I love my newly-installed Seine/SS setup but I have to lean forward a bit and straight-arm it to get 5th. another couple of inches would be great.
I just installed the Seine shift kit and Weltmeister short shift kit. My 1971 911 T with 915 trans. Goes into all gears. What I did notice that the short throw does not let the welded tabs to engage all the way. See pics. Pic. 1 show's 1st. Gear position then 2nd gear position and then Neutral position. Is this normal? Is this because of short shift kit?
Just search for shift linkage on Pelican. Search the threads for info on rebuilding your coupler, or just buy a new aftermarket or stock one.
It is just a bushing that fits on the ball on the bottom of the shift rod, a bushing just behind the shifter in the tunnel for the linkage and then the coupler bushings, or an aftermarket version, I bought the Stomski one after I found my couplers bushings had disintegrated. I think it works great, but because it has no slop, adjusting it takes a bit of fiddling.
Rutager West 1977 911S Targa Chocolate Brown |
Here’s a great link
Shift Coupler & shift lever bushings replacement tutorial made easy-step-by- step
Thank you
different than the Porsche OEM stick. Most folks opt for the Porsche short shift kit with a Seine. Used to have a Weltmeister SS but hated it as the stick was way too short.
non-whiner
I replaced the listed components and installed a Seine Gate. What an amazing difference! I made a video to show the difference. I wish I would have made a “before” as the change was dramatic. This is the 915 driven by a 1995 3.6 in my 1975 911.
https://youtu.be/ai-jOCBiQVw
"Too much is just enough." |
