Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Cylinder #6 exhaust port resembles a volcanic cave
So I pulled the heat exchangers off to see if they can at all be salvaged for the time being. I got looking at the exhaust ports and noticed some I liked and some that I didn't. Being new to the 911 motor I would like some expert eyes to give me an explanation. I am assuming that it could be a bad valve guide/seal. The motor has been apart at some point in its life. I am not sure on all the details of what has been done. Looking through the injector holes (new o-rings) all the intake valves looked fairly clean and shiny, I don't think I was able to get a good look at the back two cylinders especially #6. So it may be another story. Also the motor has only run about a total of 10 minutes or so in the last 8 years. So I have not even run it through a full heat cycle yet since I have owned it. As far as I know it is still a stock configuration 2.7.
Cyl. # 1
Cyl. #6
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 04-26-2013, 10:20 PM
Senior Advisor
James Brown's Avatar
yeah looks like crud, might be residual fuel carbon but, the valve guide is a tad wet. see the white edge of the carbon shows that it got real hot, might be oil carbon. since it faces down, you can scrape most of it out, make sure the valve is closed. i would definitely look at the #6 injector with zeal now or swap out #1 for #6 injector
08 Cayenne Turbo
Old 04-26-2013, 10:36 PM
Will work for parts
944 boy's Avatar
I rebuilt the Fuel distributor and did a flow check on the injectors. They were as even as i could measure with un-graduated containers.
I have the parts and tools to check valve clearances but have yet to do that as well. I will also be doing a compression test this weekend. I am mostly still checking out the motor for any MAJOR issues that require an immediate tear down.
Old 04-26-2013, 10:47 PM
Senior Advisor
yeah it could be very old stuff that has been in there for a long time. Good that you flowed the injectors just clean and go!! Can you do a leak down test?
08 Cayenne Turbo
Old 04-26-2013, 10:58 PM
Looks like a worn out guide & seal to me.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-26-2013, 11:22 PM
Senior Advisor
oil coking ya think
08 Cayenne Turbo
Old 04-26-2013, 11:36 PM
