Seriously? Air flow (fan speed) has everything to do with freeze up. Think about it.
On the other hand yes, provided the control system is faulty to the point of allowing evaporator freeze-up, but has "limited" refrigeration capacity, with a high(er) volume of airflow, airflow consistently ABOVE 32F, no freeze up will result. But keep in mind that like your fridge's freezer section, your A/C is a closed system and will FREEZE unless you open the "freezer" door often enough. |
where do you come up with this stuff?
what if the water is already 33 degees? go pull the fuse to the indoor unit of you home AC and watch how fast the evap will freeze up. why do you think one of the first things to check on a home AC unit is the air filter. a dirty air fitler reduces air flow and WILL cause the evap to freeze. |
I have 2 of those ~12,000 BTU portable air conditioner/heat pump (exhaust/intake air hoses through the window) units for heating the 2 garages on the property, and they both have active freeze up prevention controls. |
And amazing so many older home HVAC units don't utilize an evap freeze out switch. So inexpensive to adapt. Most 'in the window' or 'in the wall' don't have them either, I've seen many units just turn to a block of ice, brand new, right out of the box. So, we are fortunate the 911/930 have a simple and effective 'thermostat-freeze out' combo control that if properly located in the evaporator coil... works! |
Simplistic, now there is a word German engineers would like. |
| All times are GMT -8. The time now is 08:23 AM. |
