-   -   a/c problem (http://forums.pelicanparts.com/porsche-911-technical-forum/746040-c-problem.html)
mitchneher 04-22-2013 08:15 PM
a/c problem
hi I have a '77 3L with an aftermarket a/c converted to r-134 by the first owner ( i'm the 2nd). The system performs normally for 45 min and then the evaporator freezes. r-134 pressure is within limits and front condenser fan is functioning. What's up?
DRACO A5OG 04-22-2013 08:28 PM
try reducing the refrigerant by 20%
wwest 04-22-2013 09:29 PM
Not sure, but I seem to remember that there is a calibration adjust screw on the thermostatic control switch regulating the evaporator core temperature. Insert the capilary tube end into an ICE BUCKET "standard" and adjust the screw such that the contacts always open at 32F.
billybek 04-23-2013 05:33 AM
Make sure that your evaporator fan is running on high speed. If not adding enough heat to the system you will be prone to freezing. More causes of low air flow could be a restricted supply or return to the evap or a dirty or partially plugged coil or even air bypassing the coil due to a bad seal between the evaporator and the housing.
When the system is working well, what is your outlet air temperature from the vents?
T77911S 04-23-2013 06:56 AM
try the above if you can adjsut the cap tube, or at least verify it works. they are filled with refrigerent and if it leaks out, they dont work. also, make sure it is even inserted into the evap. some people will leave them out thinking their system will blow colder.
the few 930/911 AC systems i have worked on, and from what i have been told by my porsche mechanic friend, 911 systems run higher pressures. if you charged based pressure alone, it may be under charged.
when the system is under charged, the evap freezes
kuehl 04-24-2013 02:13 PM
Actually the screw on the thermostat offers very little in adjustment, the range and "Hysteresis" are set at the factory. We have talked to the factory engineers. Although you may find a post here in the forum about someone whom did play with the adjustment, a new thermostat properly installed does not have freezing issues. Most issues with the thermostat and freezing relate to either:
A) The capillary sensing tube is not making good contact in the evaporator (the aluminum fins have been pushed away from the probe or the probe in its brass sleeve).
B) When the thermostats get old they can fail in a contact closed position.
AIR CONDITIONING HELP HOME PAGE,a/c,ac,air,air conditioning,barrier hose,Behr,Bosch,compressor,compressors,condensers, condenser,condensors,drier,driers,dryers,evaporato r,evaporators,freon,Griffiths,improvements,Kuehl,N ippondenso,Porsche,r12,r134a,San
SilberUrS6 04-24-2013 03:10 PM
Question:
I have some thermal paste left over from a computer build I did some time ago. If I used that paste when inserting the capillary tube, would that be a good thing? Or a bad thing?
wwest 04-24-2013 04:20 PM
There isn't very much range of calibation required. Put the "probe" in a ice bath, adjust the "screw" so the switch is distinctly open with the control knob FULLY clockwise..MAXIMUM cooling. The switch should close with the slightest CCW of the control.
An ice bath can be as simple as large bucket filled with shaved ice, or findly chopped ice, and filled with water below the level of the ice an inch or 2. Insert the capillary tube/bulb into the center, well into the water/ice mixture and allow a few minutes to stabilize.
This is NOT rocket science.
wwest 04-24-2013 04:31 PM
Originally Posted by SilberUrS6 (Post 7405535)
Question:
Wouldn't matter.
kuehl 04-24-2013 04:54 PM
Question:
Just so you understand, you don't have to "adjust any screw in the thermostat".... that is SNAKE OIL..... LOL. You can monkey around with the screw till the cows come home and if the probe is not making good contact with the fins in the evaporator in the right location it won't make a difference. They are set at the factory and seldom drift from that setting either. But, Wwest might be willing to fly over to your place and adjust it for you... lol, he sounds like an eager puppy tonight. Down Boy!
I can tell you this because we have installed many in the past 20 year and we have sold 100's. We sell new units because they sometimes break when you bend the aluminum tube extensively or when they fail in an open or closed position.
And, location of the probe varies from evaporator to evaporator.
OEM pre 86 coils are different than 86-89, and as well when it comes to
serpentine units from various manufacturers.
Does thermal grease help, YES.
Will thermal grease solve your issue. Don't think so in this occasion.
Location & Contact.
SilberUrS6 04-24-2013 05:49 PM
Location & Contact.
Hmmm, I don't know anything about any "screw" - I don't know what you're talking about there.
I was just thinking of making sure my capillary tube was making full thermal contact with the fins of the evaporator. Since I had some paste left over, I figured I'd put that paste to use. :)
mitchneher 04-24-2013 05:57 PM
when operating the vent temp is 45 deg
kuehl 04-24-2013 06:03 PM
Concur on the getting screwed thing.
Moving on...
What you can do is, if you still have it, inject the thermal grease in the brass sleeve, about half full (you can use a syringe) and then insert the cap tube into the sleeve to its bottom.
The cap tube with sleeve on a 77L vintage evap, assuming it is a Behr evap, goes in 3" straight down vertical I believe. If you still have the freezing issue you could drill a 1/4" in hole (adjacent to the current hole in the top of the Behr box) placing this hole as close as can nearer the fan's shroud (shroud is the large round plastic riser that house the evap fan blower cage), this might get you into some 'fresh' fins in the coil; but be careful not drill more than 1/4" into the top of the box so you don't drill in a coil (ouch).
If you decide to relocate the cap tube like this you will want to take a thin piece of say welding rod or a coat hanger (something thinner than the diameter of the cap tube or brass sleeve) and create a 'pilot' hole into the new section fins. You'd press this rod down into the fins and without too much effort so you don't puncture a refrigerant tube... follow?
Or remove the top of the evap box, exam the area where you have been trying to insert the cap tube presently, and you'll see the fins have been pushed back.
You can go to our website, find our phone number and call us if you need more direction.
Removing or adding refrigerant to the system should not have any affect on the "function" of the thermostat; more common a procedure on home central air, industrial or commercial refrigeration units that don't have freeze out switches.
kuehl 04-24-2013 06:06 PM
That is over a 13 degree loss of cooling through the vents... hmmmm.
What fan speed was the temp taking and what instrument was used to note the
vent temp.
wwest 04-24-2013 07:55 PM
Yes, the calibration "screw" adjustment is intented just for factory use. But if you're havingh evaporoator freeze up symptoms then the calibration might be one of the 2 or 3 causative factors. The tension of the "spring"/bellows might well change over time.
Yes, IF...But, on the other hand if the probe is properly positioned, and other possible causative factors are ruled out, then the calibration aspect may be well worth checking.
Yes, agreed, "seldom".
No, but if your last resort is sending it to me for calibration I would be glad to be of help.
"Sold hundreds.." Obviously with no feedback methods to ascertain the failure mode of the unit being replaced, gas leakage, contacts welded shut, nor calibration drift. My experience should be considered NIL in comparison but I have corrected freeze up issues by calibrating the control.
Location & Contact.
Since the factory system does not rely on the "close" thermal coupling that would be provided via the paste the only result might be a slight reduction in the hysterisis "span".
kuehl 04-24-2013 08:08 PM
No, the last resort is to send them to you and tell you where to stick it! lmfao
No. wrong again son. Time to take your xanax.
If a thermostat is 30 years old and it fails because the contacts are shot, or because the aluminum tube broke when handling it... because you did not read the directions, and you know the 'calibration' does not drift, wtf would you have a client send you a broken 30 year old thermostat and write a report? Do you return your worn tires or brake pads back to the mfg for an analysis? Rhetorical question.
"THIS IS NOT ROCKET SCIENCE" lol.
PS. our thermostats come with instructions. :D
Time to go while wwest is on his merry go round
wwest 04-24-2013 08:08 PM
vent temp.
What does fan speed have to do with evaporator freezing up? Even if the fan speed were ZERO the control system should prevent freeze up.
Either the probe is not properly positioned, the control contacts are welded shut, or for some other reason the control system is not cycling the compressor clutch OFF correctly.
kuehl 04-24-2013 08:11 PM
Because you have been a bad boy, we are not going to tell you:)
wwest 04-24-2013 08:21 PM
[I]"Sold hundreds.." Obviously with no feedback methods to ascertain the failure mode of the unit being replaced, gas leakage, contacts welded shut, nor calibration drift.
Yes, If I were to report failure modes "here" as you seem wont to do then of course I would ask clients to provide foundation data. Otherwise your statement are simply GUESSWORK...but then I GUESSED that long ago.
I have done EXACTLY that due to unique product failures that the manufacturer became aware of and requested the broken item be returned.
Time to go Wwest while wwest is on his merry go round
When you recieve new thermostatic controls from your vendor what level of assurance do you have of proper calibration.?
wwest 04-24-2013 08:25 PM
BS, admit that it was simply an inappropreate question on your part resulting from your VAST experience but TOTAL lack of knowledge.
