heat is your best friend, just removed all 12, no issues, some even look brand new with coating still intact
I have 1/2 of my second gear glued to the side of my tool box.....
Hey, your garage looks like mine! If the rest of the bug is as nice as the front fender, that looks like a really nice car! Now we're really getting off track.... :)http://forums.pelicanparts.com/uploa...1366807905.jpg |
You're not a real air cooled 911 owner til you've enjoyed spending time with broken head studs. I went Supertec so that it won't happen again & again & again
PS. What moronic mechanic would replace just one head stud? |
You just havent LIVED unless you have suffered a broken headstud
[IMG]http://i1311.photobucket.com/albums/...ps0d4aea42.jpg[/IMG] And I carry it around in my pocket ........not sure why |
FWIW, "Divilar" and "Dilivar", if accurately identified, are knockoffs of genuine Porsche Dilavar head studs. As such, they're not the real deal and probably made from some inexpensive, not-to-spec, good-enough material. It's like a "Rolex" watch that lasts 2 weeks. Rolex doesn't like knockoffs. Neither do unsuspecting consumers.
If it's merely a misspelling on your part, you could have an earlier version of the real thing (black coated are version 3 or 4). The fully threaded versions (993) are the latest. I think Dilavar studs were offered in at least 4 versions through the years including a defective batch from the factory. Sherwood |
What we never learned was if the defective studs were from inside the dealer system, or were they bought outside from a wholesaler? We knew of a second case that was similar, and we knew that our primary source for wholesale purchases pulled a large quantity of studs from their inventory. We also never learned if those studs were o.e., or a knock-off. Very worrisome time, during which my shop did a couple stud replacement jobs, but we bought our new studs from a dealer (not Ogner) that was convenient to my shop. I think that I "held my breath" for a couple months, but both cars returned for their 1,000 mile service, and neither ever had a problem. Whew! |
I wish mine was that short. It broke very close to the case.
It's too long to carry in my pocket ... |
Dilivar death
Rokemester, where r u located?
I too have beverages in the garage. Can't do good work without refreshment. The stud replacement will take a long time. I'm planning a full rebuild and that's going to take more money than I can think about without beer. The stud removal should be within my pay grade....I'm an old machinist....very old. I will soak them for a couple of weeks (Kroil ?) then use propane heat and magic spells to get them out. If I'm successful I may hire myself out for refreshments. If not successful I will hide from the world. |
Concentrate! Back to the head stud! http://forums.pelicanparts.com/uploa...1366846506.jpg |
OK By me.
I often feel a pair of nuts when I reach in my front pockets. |
Tomato, tomaaato, dilivar, divilar, dilavar. Should have been "Another broken dilavar head stud sob story" My bad! I really am not that bad of a spellar...speller.
Having different headstud material on top and bottom......stupid freaking idea.......just sayin'.....
It sure has me confused!!! I suppose it makes sense to have head studs that cool and heat up at the same rate as your case if your driving your 911 daily...and like you stole it. Me, I'm just the typical late 50s kid that always wanted a real Porsche (had a 75 914 which I loved and had to give up when the kids started to go to college, but I digress). I drive the Targa whenever I get the chance and then it goes into the garage for the winter with mega salt on the roads here in NEO.
By the way here is a great post from some guru on the genesis of dilavars: Head Studs? - Rennlist Discussion Forums Believe me I've been doing some homework. |
Sherwood |
They had a need to fix a problem....a long standing problem....they made a wrong decision.
They screwed up the 2.7, then made a stud change for the 3.0. How many years was that span? I will admit that the 2.7 was hosed by the US EPA and the studs pulled because of the add on smog/thermal reactors excessive heat. But the 3.0 had an air pump....no TRs and a different case. They made a bad decision with the 3.0 and never manned up on it. Kinda like Bentley never admitting that they made the firing order bassackwards. |
| All times are GMT -8. The time now is 03:07 PM. |
