rokemester's Avatar
Another broken Divilar head stud sob story
Is there something wrong with me if I carry one of my two broken head studs around in my pocket? It's the only piece of my 911 that will be with me for the next couple of months. Just when the driving season is ramping up in Northeast Ohio.
Old 04-22-2013, 08:54 PM
Banned
Nope. Nothing wrong at all. Just don't admit it to anyone else. They will look at you funny. I, however, understand completely.
Old 04-22-2013, 09:27 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Wish there was a "Like" button
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-23-2013, 05:04 AM
cycling has-been
bkreigsr's Avatar
sounds normal to me... I still carry around a tooth from the ring gear that exploded on my 77 Skylark...
Bill K
Old 04-23-2013, 05:27 AM
rokemester's Avatar
Thanks for your empathy! It just came to me. While I work through the upcoming repair drama I'll post pictures of the head stud in different locations, kind of like Flat Stanley.
In my office:
Old 04-23-2013, 06:18 AM
rokemester's Avatar
...does anyone know if the original dilivar studs they would have used in 1987 coated? I have learned from other threads that today's dilivar studs are now coated to improve corrosion protection.
Old 04-23-2013, 06:20 AM
If you rebuild the engine yourself, then you'll have LOTS of your 911 with you all the time!
Stuck under your fingernails, gooped in your hair, sharp shiny pieces stuck into your fingertips, some of it in your eye...
My 911 and I became intimately acquainted when I work on it...
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-23-2013, 07:19 AM
Sugar Scoops Rule :)
dave 911's Avatar
At least you have your favorite alcoholic beverage next to the broken stud...the 2 go hand in hand for sure....
And the glass is empty also...
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 04-23-2013, 07:32 AM
Charles Freeborn's Avatar
At least you didn't fry a piston. That would look goofy in your pocket....
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 04-23-2013, 10:33 AM
Peter Zimmermann's Avatar
Dilavars, beginning with 1982 production, were coated.
The pictured broken stud appears odd in that I can't see the normal corrosion that is usually present. It also looks like the stud is scratched...???
Keep the Shiny Side UP!
Pete Z.
Old 04-23-2013, 11:01 AM
rokemester's Avatar
I will try to get a better picture with more detail. Like a few others I should have had a thorough PPI including pulling the valve covers to find any dropping surprises. It is possible when I bought the car two years ago the dilivars were fine, I will never know. Supposedly a top end rebuild was done at 157,000 and I took ownership at 159K. If a top end was done can't figure why all twelve lower head studs would not have been replaced. Unfortunately I have been unsuccessful in tracking down the mechanic that did the work.
Old 04-23-2013, 02:05 PM
I found all 12 Dilivar studs broken last week. They allowed exhaust gasses to melt the sealing surfaces on the cylinders and heads. I didn't have a PPI either. I have owned the car for 3 years and driven 10 miles. I thought the CIS was responsible for the lousy starting and running. I think I was wrong.
I love the car and am too stubborn to not get it right. Just takes time and money.
If you don't know about your studs find out right now. It's much cheaper.
Now where did I put my beverage?????
Old 04-23-2013, 03:18 PM
rokemester's Avatar
That's what I really love about this forum. There is always someone who is suffering the same or more than you. Hey Columbus Indiana isn't that far away. I always have cold beers in the garage!
Note that alcohol always seems to be part of the theme. These cars can lead you to drink!!
Old 04-23-2013, 05:55 PM
rokemester's Avatar
I really like to work on my 911 but I know my limitations. Brakes last year, most recently the notorious autoheat system. Broken head studs, way above my pay grade
Yes that is a 66 Bug peaking out of the corner. Now that is a car I can handle...some of the time.
Old 04-23-2013, 06:06 PM
rokemester's Avatar
...I ended up splitting the original calipers and had them anodized. Hey I'm hijacking my own thread!
Old 04-23-2013, 06:11 PM
m110's Avatar
Anodized?
You mean cadmium plated, right?
1988 Carrera Coupe
Old 04-23-2013, 06:51 PM
rokemester's Avatar
Zinc coated? The sacrificial coating that was OEM. Good catch!
Old 04-23-2013, 07:25 PM
Straight shooter
Lapkritis's Avatar
Looks exactly like my broken stud... no coincidence.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-23-2013, 07:30 PM
rokemester's Avatar
And I thought I was having issues. This was posted in the classified section:
Dilvar Studs - almost nightmare of replacement
Great thread, a sob story with a happy ending.
Old 04-23-2013, 07:39 PM
redstrosekNic's Avatar
I'm liking the flat stanley style idea
Your car will be back to health in no time!
Dustin
Old 04-23-2013, 08:41 PM
