-   -   refinishing fuchs question (http://forums.pelicanparts.com/porsche-911-technical-forum/746101-refinishing-fuchs-question.html)
tomdeg 04-23-2013 08:04 AM
Hi All,
How are original Fuchs finished before they are anodized? Are they glass beaded, or polished?
Thanks,
Tom
combatic 04-23-2013 11:27 AM
ala search function. Jacks excellent review....Fuchs History
porschenut 04-23-2013 12:19 PM
The entire wheel is anodized and then the center is painted.
tomdeg 04-23-2013 02:51 PM
Yes, but before the wheel is anodized, is the wheel blasted or polished, or ?
msterling 04-23-2013 03:11 PM
Read the link to Jack's article. Here is an excerpt with your answer:
From Porsche 911: Forever Young, by Tobias Aichele
"To be precise, the Fuchs wheel was formed by the following steps. A pressed piece of stock was forged to make a forging blank. Next, drop forging the blank produced the ventilation holes and deburred the flange. A further drop forging step resulted in a split flange, before the workpiece was widened by rolling. And here is the secret advantage of this complex manufacturing process: the Fuchs wheel stayed in production for so many years because it could be rolled to any width desired. The forming process resulted in a wheel with a completely finished inner side. The outer, visible side of the wheel was turned on special lathes, which resulted in the smallest possible wheel imbalance. A carefully developed surface finish -- polishing, anodizing, and painting -- permitted different design variations over the years and assured high corrosion resistance."
