-   -   Just a hint for any noobies! (http://forums.pelicanparts.com/porsche-911-technical-forum/746249-just-hint-any-noobies.html)
crownarch 09-11-2013 06:40 PM
When I grabbed the factory tool for the first time I thought it looked too big, too long and kind of crude. However, I quickly found that it is really a great tool for removing the plugs.
Bob Kontak 09-11-2013 07:06 PM
Originally Posted by James Brown (Post 7404154)
your right, there wrong
For years I have used the same setup except instead of the swivel I use an added stubbie extension. Maybe 1 1/2 that matches the swivel length.
When I pull it out of the hole I have to pull the stubbie off to clear the engine sheet metal. With the swivel, I can see where you can just pull the wrench up to clear the sheet metal and no extra work is needed.
Thanks for the tip George!
donlan 09-12-2013 11:10 PM
Sounds good to me.I will make one as I am one of those blokes that bought a car WITHOUT a tool kit.Michael.
porsche0nut 09-13-2013 10:05 AM
Originally Posted by Porchdog (Post 7651698)
The plug wrench was missing from my tool kit...
LOL I never even thought to check my tool kit.... which is complete and lying right next to my toolbox!
AVIMAX 09-13-2013 10:18 AM
The tool kit is very good, you can do many jobs without any additional tools. I removed the fan assay and alternator using only the tools that came with the car.
RWebb 09-13-2013 12:50 PM
Snap-Off makes some nice locking items that obviate the need for duct tape, welding, etc. etc.
juanbenae 09-13-2013 12:56 PM
Originally Posted by georgew123 (Post 7403667)
Just to add to that tip... I put some electrical tape on the joint to firm it up a bit to help locate the socket onto the plug (removal) and locate the new plug (install) into the threads.
wow, great idea! not just for spark plugs, but elsewhere the floppy swivel has caused me heartburn. best nugget in this thread for this noob....
theiceman 09-22-2013 02:44 PM
Well I just came home from a car show and picked up a 3 inch extension, a swivel and a spark plug socket for a buck each. I will now have a welded up permanent tool in my tool chest for 3 bucks.
I have the factory tool but this is way easier than breaking out the facttory tool kit. That is neatly bundled up in the front of the car.
Jerome74911S 09-22-2013 03:02 PM
Originally Posted by redstack (Post 7651325)
So you think that this $15 tool will be able to maneuver in the engine compartment?
The car I'm buying doesn't have the tool kit.
There's an Advance Auto Parts near me. I'm going to get one of those tools and forget about cobbled together arrangements, even if they do work. That tool is elegant. I have done plenty cussing with my poor DIY efforts, and this looks as if it will clean up my act.
Also, I've never even seen the factory tool, never mine own one.
Kidasters 09-22-2013 03:17 PM
Another vote for the factory tool.
I like it so much, I bought an extra, so I don't have to open the trunk and dig around.
PushingMyLuck 09-22-2013 05:53 PM
Who here has actually changed the plugs more than once ?
BlkBird 09-22-2013 06:27 PM
My factory spark plug doesn't fit my aftermarket plugs. Joys of having super duper Turbo plugs. And that cursed inter cooler needs to come out and... All afternoon job for me I suspect.
theiceman 09-22-2013 06:30 PM
Huh? I replace them every two years religiously.. And I only drive summers..
Reiver 09-23-2013 12:24 PM
Every year at valve adjust time.
theiceman 09-23-2013 12:40 PM
Well i just scored a major bonus ... the used extension and swivel i bought must have been outside for a while so the tiny ball and spring were completely seized.. had to hammer the bastard thing together .... no welder needed :D
Nostril Cheese 09-23-2013 01:54 PM
This is what I use. Snap-on 13/16th's swivel spark plug tool. It has a magnetic insert that holds the plug so that you dont get it stuck on the plug down in the valve cover.
http://forums.pelicanparts.com/uploa...1379969610.jpg
PushingMyLuck 09-23-2013 04:27 PM
Is this necessary? Plugs go 100k miles on modern cars.
Is this b/c of the modern plugs, or b/c of the modern ignition systems?
RWebb 09-23-2013 05:06 PM
both - also, modern fuel mgmt systems
4SFED 10-27-2013 06:26 PM
Have a very similar setup with electrical tape and it works flawlessly on 4 cyls.... #1 and #6 are darn-near impossible. I still can't get to #6.... :(
redstrosekNic 10-27-2013 08:11 PM
Weird. Do you have a pic of your set up? I have no issues with any plugs using my combo.
