Just a hint for any noobies!
I decided to change my spark plugs today. I was a bit nervous, as I had searched through all of the discussions of what tool(s) to use, and saw quite a bit of disagreement.
I was able to change all 6 plugs in under 30 minutes using this combo... http://forums.pelicanparts.com/uploa...1366761537.jpg A simple 13/16 spark plug socket, a knuckle, and a short extension. A thought to keep in mind, though, is the fact that I have backdated heat, which made the job easier. Just a tip for anybody afraid to tackle this! BTW...my 911 seems to like the NGKs I threw in there... :) |
Just to add to that tip... I put some electrical tape on the joint to firm it up a bit to help locate the socket onto the plug (removal) and locate the new plug (install) into the threads.
another tip is to take that assembly to a welder and zap it together so it doesn't find a dark hole when your doing #6 at night in the rain
James, I'm glad you said that about welding. I have often thought that the best thing to do was to make a good tool permanent just for doing the plugs on a 911.
Hi all,
The best tool I have found for replacing the plugs is the factory tool found in your tool kit!! Just a thought! ;) |
"The best tool I have found for replacing the plugs is the factory tool found in your tool kit!!"
I agree. |
+1
I can't imagine the factory tool making the process any easier. The set-up I used was an absolute breeze :) |
your right, there wrong, i use the exact same thing, love it. I also use a snap-on flex head ratchet, perfect!!
Also try to make sure that the hold on the plug in the socket is looser that the other joints in the Assembly of tools, so it will come out first rather than cause the socket to come adrift from the rest of the tool.
Cheers Richard |
I didn't need that 4" extension anyway... |
agree with others about the factory tool. I have a couple, they are always perfect
if you must use a extension, use a 3" locking extension, I wouldn't bother with the swivel |
They make spark plug sockets with swivel extensions already integrated on them.
Almost like someone somewhere might have come across a similar problem before :p Oh, some come with a 6 inch extension as well, and some are magnetic instead of having the rubber insert. |
So you think that this $15 tool will be able to maneuver in the engine compartment?
The car I'm buying doesn't have the tool kit. Buy Gear Wrench 13/16" x 6" Magnetic Swivel Spark Plug Socket 80547 at Advance Auto Parts |
There's a guy in the classifieds selling a bunch of loose tool kit tools. Has several of the spark plug wrenches.
Yes, looks good. I have been told that I need a 4" extension.
1973 911 T MFI Coupe, Aubergine Steve |
My custom tool... the extension kept pulling off my plug socket (leaving it in the engine) so I decided they needed to be joined permanently. It's about a 3-4" extension. Works beautifully and doesn't require any special pieces.
http://forums.pelicanparts.com/uploa...1378949264.jpg |
The plug wrench was missing from my tool kit. I've been using the Gearwrench tool and i'm very happy with it - the right amount of grip on the plug and the right amount of stiffness in the swivel.
I did see Bruce's ad today, I ordered one from him to complete my tool kit. Neve know when you need one away from home. |
When I grabbed the factory tool for the first time I thought it looked too big, too long and kind of crude. However, I quickly found that it is really a great tool for removing the plugs.
When I pull it out of the hole I have to pull the stubbie off to clear the engine sheet metal. With the swivel, I can see where you can just pull the wrench up to clear the sheet metal and no extra work is needed. Thanks for the tip George! |
Sounds good to me.I will make one as I am one of those blokes that bought a car WITHOUT a tool kit.Michael.
The tool kit is very good, you can do many jobs without any additional tools. I removed the fan assay and alternator using only the tools that came with the car.
Snap-Off makes some nice locking items that obviate the need for duct tape, welding, etc. etc.
Well I just came home from a car show and picked up a 3 inch extension, a swivel and a spark plug socket for a buck each. I will now have a welded up permanent tool in my tool chest for 3 bucks.
I have the factory tool but this is way easier than breaking out the facttory tool kit. That is neatly bundled up in the front of the car. |
Also, I've never even seen the factory tool, never mine own one. |
Another vote for the factory tool.
I like it so much, I bought an extra, so I don't have to open the trunk and dig around. |
Who here has actually changed the plugs more than once ?
My factory spark plug doesn't fit my aftermarket plugs. Joys of having super duper Turbo plugs. And that cursed inter cooler needs to come out and... All afternoon job for me I suspect.
This is what I use. Snap-on 13/16th's swivel spark plug tool. It has a magnetic insert that holds the plug so that you dont get it stuck on the plug down in the valve cover.
http://forums.pelicanparts.com/uploa...1379969610.jpg |
Is this b/c of the modern plugs, or b/c of the modern ignition systems? |
both - also, modern fuel mgmt systems
Have a very similar setup with electrical tape and it works flawlessly on 4 cyls.... #1 and #6 are darn-near impossible. I still can't get to #6.... :(
| All times are GMT -8. The time now is 02:51 AM. |
