-   -   uneven trottle response? (http://forums.pelicanparts.com/porsche-911-technical-forum/746478-uneven-trottle-response.html)
ian s 04-24-2013 08:23 PM
Took my 86 3.2 cab out today and noticed that it has developed some noticeable flat spots (for lack of a better term) in the power delivery vs throttle position. If i hammer down it runs up perfect and does not lack power. Under light loads or slow accel it can be very uneven and at times, even feels a little jerky. Up over 4k it seems to go away entirely? as you bring it up through the revs at lets say 1/3 power it accelerates very unevenly and again almost seems to hit a flat spot in power untill you give it a bit more and shell smooth right out? I guess another way to describe it would be that at times the throttle does not feel directly connected to what the engine is putting out in power. It is the first year with the Motronic so I was thinking maybe they had issues. I know im ready for a valve adjust but i don't think thats related.
Injectors?
dme?
timing?
Just bad gas?
Hoping someone else has had this exact problem and can get me dialed in on the fix.
Thanks: Ian
LJ851 04-24-2013 08:34 PM
Sounds lean. A worn AFM will act this way.
vulcan300 04-24-2013 08:38 PM
Here's one more thing to consider. It could also be the that your Air Fuel Meter has developed some dead spots in the track that the wiper slides over. This matches well with your description of proper throttle response when hammering the throttle, but noticeable dead spots when slowly accelerating.
Here's a line to a well known walk through on fixing the problem. The best part is it requires spending nothing but your time. Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com
Good luck!
