-   -   Is the Wurth Matte or Gloss black correct to refinish Carrera Fuchs? (http://forums.pelicanparts.com/porsche-911-technical-forum/746533-wurth-matte-gloss-black-correct-refinish-carrera-fuchs.html)
r-mm 04-25-2013 08:13 AM
Want to refinish the Fuchs on my Carrera and wondering what supplies you all would order from our gracious host vs buy at home depot. I should say I'm looking for an excuse to order some stuff as I need some tiny bits and pieces that don't make sense to buy alone.
Matte?
Gloss?
From what I've read here and seen, the finish seems like its more of a satin. Are either of these correct?
Driver_X 04-25-2013 08:24 AM
Rustoleum 7777 Satin Black
r-mm 04-25-2013 08:31 AM
Like this?
http://www.amazon.com/Rust-Oleum-7777830-Satin-Enamels-12-Ounce/dp/B00166QNGW/ref=sr_1_2?ie=UTF8&qid=1366903862&sr=8-2&keywords=Rustoleum+7777+Satin+Black
john walker's workshop 04-25-2013 08:33 AM
wurth matt black lacquer.
cpa 04-25-2013 08:55 AM
r-mm, use the Worth matte black. You won't be disapointed.
Driver_X 04-25-2013 10:16 AM
I did some other bits & pieces with the rustoleum and it looked great, but for wheels I would probably cough up the extra dough for the Wurth. But people here have used both with great success. Just stay with the satin finish IMO. Glossy is too, well, glossy :-)
r-mm 04-25-2013 10:41 AM
Well I called Pelican and they confirmed that neither Wurth product has the 'correct' gloss level, which I think is important to get right. I don't need perfection in the application, this is a driver, I just want a deeper black than I presently have on my chalky wheels. I'm inclined to give the Rustoleom or something like this a shot: Satin Black Wheel Paint 12 oz Aerosol
Can anyone share their prep / priming steps? Did you take the petals down to bare metal?
Arne2 04-25-2013 10:47 AM
First time I repainted my centers, I used a can of Krylon satin black, as I already had a can on the shelf. Looked correct and nice. I'm refinishing them again (http://forums.pelicanparts.com/porsche-911-technical-forum/716779-fuchs-faux-anodizing-what-silver-paint.html) and am using the Rustoleum #7777 satin black. Also looks correct to my eye. So I'm guessing that most any decent quality satin black should be OK for a driver.
r-mm 04-25-2013 10:52 AM
There seem to be a lot of votes for the Rustoleum option. I had a very good experience with VHT's wrinkle finish for my Alfa twin cam valve cover so this is also an attractive option: VHT SP183 Satin Black Wheel Paint Can - 11 oz. : Amazon.com : Automotivehttp://forums.pelicanparts.com/uploa...1366912303.jpg
john walker's workshop 04-25-2013 12:35 PM
i guess they don't have the matte black lacquer then. it's perfect.
r-mm 04-25-2013 12:37 PM
They do have the matte black (I linked to it above...) but I was told its less glossy than the factory finish.
Arne2 04-25-2013 01:28 PM
Wurth makes (or made?) three different levels of gloss in black - matte, satin and gloss. I'd always thought the satin was the correct one for this. Griot's used to offer a nice German satin black, too. But I no longer see it on his website.
john walker's workshop 04-25-2013 03:09 PM
matte is not flat. it has a slight sheen.
r-mm 04-25-2013 06:38 PM
Got started stripping my wheels. Used a gel stripper and variety pack of wire brushes along with some scotch bright. Took a number of passes for sure but got two done in about 2 hours. http://forums.pelicanparts.com/uploa...1366940233.jpg
http://forums.pelicanparts.com/uploa...1366940282.jpg
rokemester 04-25-2013 06:45 PM
Are you trying to retain the original anodizing? I thought mechanical removal of paint with wire brushes would remove the anodized coating?
r-mm 04-25-2013 06:47 PM
I am trying to keep the anodizing on the rim and repaint what was previously painted. I'm not using power tools and trying to be careful around the rim.
If the paint was previously applied on anodized metal... well it won't be anymore.
ganun 04-25-2013 07:02 PM
My 87 GP white coupe but with factory option white wheels.....My first reaction was to paint them black when I first got the car, white is absurd on wheels, or just stupid, but after some time I came to like them even though they are a PITA.
George Nunez
http://forums.pelicanparts.com/uploa...1366941761.jpg
porschenut 04-25-2013 07:39 PM
That's correct. The Rustoleum 7777 is NOT the correct match. It's too glossy. I've used it and compared it to brand new factory Fuchs. The correct finish is matte, not satin.
rokemester 04-25-2013 08:01 PM
Cool! My Fuchs are a bit dinged up as it is, but after 26+ years they still clean up pretty nice with some Vaseline. Your wheels look to be in much better shape than mine. Look forward to watching your progress.
http://forums.pelicanparts.com/uploa...1366945207.jpg
http://forums.pelicanparts.com/uploa...1366945238.jpg
I cleaned up and painted the center caps at the end of the driving season last year.
MConn 04-25-2013 08:15 PM
Will 1 can of Wurth matte black cover all 4 wheels, or do I need 2 to be sure I have enough paint?
Mike
NoYouRelax 04-25-2013 08:21 PM
I used Rustoleum "High Heat Ultra" as recommended by others on here and got great results. Not glossy and not flat.
DanielDudley 04-26-2013 05:53 AM
I think for ease of use, Wurth's is easier to spray to a perfect finish.
bavaria911 04-26-2013 06:31 PM
At Hershey, I purchased a can of Wurth Semi Gloss Black to paint my 380mm stock Porsche steering wheel. I removed the standard horn button to replace it with a 60's hockey puck style, but the spokes were scratched too much. I'll post a finished photo later.
Vr,
Scott
pub911 04-26-2013 06:42 PM
There's no accounting for taste, they say, but for what it's worth, I really like the job Wheel Enhancement did on mine. Highly polished aluminum rim with satin black spokes and hand painted traditional Porsche crest centers. The color of the car is black and the satin really sets off nicely from the gloss body finish.
r-mm 04-28-2013 04:06 PM
Wheel Enhancements came recommended. Can you share with us about how much they charged you?
Arne2 04-28-2013 05:18 PM
Reviews for Wheel Enhancements are a mixed bag. Some people give great reviews, some -- not so much. Seems like I've heard a lot more good than bad over the past year or so.
cpa 04-28-2013 05:31 PM
Wurth Matte Black
Buy two, you will problably need them, and if you don't you will need to have some for touch up. Best product on the market. Good finnish, best spray quality and closest to the original.
cpa
theiceman 04-29-2013 04:51 AM
cpa
it comes in a big can, i did all my wheels several coats, painted the grill for the air intake and the wheel centres, all my lug nuts .. and STILL have half a can left ..
jhhaas 04-29-2013 06:45 AM
I just painted mine last night with Krylon satin black. Mine are for a Gulf Blue SC race car so perfection was not imperative. I painted the centers and the outers. Anyway, my question is, do I clear-coat over the paint? I bought the clear coat and was planning to shoot them tonight. I was thinking it might provide a little more protection against all the brake dust and frequent tire changes. Any input is appreciated.
speednme1 04-29-2013 07:37 AM
Auto trim paint might be the look you are looking for. Dupli-color or SEM brand should suffice. Although on the can it says flat black,there is a very small amount of satin look to it. Pep boys should have the Dupli-color and Summit racing should have the SEM. Both will stand up to the elements.
r-mm 05-01-2013 08:52 AM
Making progress...
Stripped the paint with several rounds of gel stripper and a mix of scotchbrite & hand held wire brushes. Masked off the anodized lip with 3M Super 33 electrical tape (awesome stuff). Prepared surface with Eastwood PRE. 3 light coats of Rustoleoum self etch primer (sorta like they way they look olive drab) then 3 light coats of Rustoleoum 777 (not dry yet - better pics tonight!).
Gotta say, I've been buying all sorts of high priced spray cans from Eastwoods that don't always spray that great or stay that clean. I've overlooked good old Rustoleoum from HD for a while but was highly impressed with how well it goes on.
http://forums.pelicanparts.com/uploa...1367423463.jpg
http://forums.pelicanparts.com/uploa...1367423471.jpg
drodg 05-01-2013 04:16 PM
When you guys are using the Wurth's semi gloss black. Is this the flexible semi glosee trim paint? Thanks
drodg 05-01-2013 04:17 PM
Sorry gloss not glosee and I mean the Satin Black
porschenut 05-01-2013 05:22 PM
No it is not. The flexible trim paint is for rubber and plastic and things that bend, not for metal.
r-mm 05-02-2013 08:14 AM
Can anyone give simple explanation of how to sand out dust and imperfections? My first wheel came out pretty well. I decided to try and cover the second one while drying and like a fool managed to dump dust all over it. I've read a few accounts of how to do this for a proper paint job but how about for a rattle can lacquer?
Arne2 05-02-2013 08:35 AM
On a satin finish, you'll need to re-coat. Wet sand with 400 or 800 grit to smooth, then re-coat.
BTW, you'll need to remove the paint from the lug nut seats before you put them back on the car. Should have masked them off before painting.
r-mm 05-02-2013 08:48 AM
Thanks. On the 2nd wheel I coated the lug nut seats in grease so I hope paint removal will be simple. If not, i'd be impressed with my self etch primer.
Again what is the reason for removing the paint?
drodg 05-02-2013 09:47 AM
I have seen the matt black on our host's sight but where do you buy cans of the satin black?
r-mm 05-02-2013 07:26 PM
A few pictures after paint.
This one came out nearly dust free. The second one is rather dusty. Going to try and sand it out and recoat.
I am curious to try the Wurth Matte paint to see how it compares. Might add a can to my next order.
http://forums.pelicanparts.com/uploa...1367547871.jpg
http://forums.pelicanparts.com/uploa...1367547921.jpg
BGCarrera32 05-02-2013 10:08 PM
Boy, looks like you're right in the zipcode there...nice work!
