How Do I Add Ipod To Blaupunkt Reno ?
Anyone added an Ipod connection to a Blaupunkt Reno successfully ?
My very experienced radio guy tells me it cannot be done ?
Old 04-25-2013, 04:15 PM
Cattler's Avatar
You can always use an RF transmitter via a locally unused FM frequency. Its not as clean, but I doubt you'd notice the extra noise over the road, engine, etc.
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 04-25-2013, 06:02 PM
Senior Advisor
James Brown's Avatar
cassette adapter works pretty good, there are some specialty stereo shops on the web that do that like these guys SW STEREO SPECIALISTS - European Car Audio Products
08 Cayenne Turbo
Old 04-25-2013, 06:05 PM
If your Blaupunkt has an AUX input (don't most of them?), the Blaupunkt ipod interface presents the iPod as a CD changer to the head unit. Just about all Baupunkts know how to deal with one of those.
Interface is kind of clunky, and you need to mess about with playlists and the like. However, it charges the iPod, shows track information on the head unit, lets you control the playing music from the head unit (as though it were a CD changer).
There's another Blaupunkt cable that provides line-in to the AUX from an iPod - but you need AUX input for that, too. Don't know if that charges the iPod or not. It certainly doesn't provide control of the tracks/playlists from the head unit (which is just being used as an amplifier/speaker system).
The RF transmitters IMO are completely useless. Terrible sound, drive 20 miles and have to re-tune to avoid the local station blasting over what used to be an "empty" space in the band etc.
If you have an AUX interface on your Reno, I suggest the appropriate thingy Blaupunkt built for the job gives the best results: http://www.amazon.com/gp/product/B000BFJ3T8
In the interest of full disclosure, I should point out the used one offered there is actually mine - and that I removed the Blaupunkt Memphis it was attached to (for 2 weeks) and replaced the head unit with an Alpine iDA-x100, precisely because the iPod integration on the Blaupunkt did not please me. Might be fine for limited use.
'77 S with '78 930 power and a few other things.
Old 04-25-2013, 08:06 PM
Norm Faustino's Avatar
Sounds like your very experienced radio guy needs a lesson in 2013 tech. These days there is a way to interface practically anything.
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 04-25-2013, 10:10 PM
I have just done this on my Blaupunkt SQR 47 Atlanta. I believe these two models are almost identical - in fact they share the same electrical schematics. (I can email these to you if you need them)
There is two parts to this: (this method does require you to open up your stereo unit and solder wires onto the electrical board)
1. First you have to input the signal from your iPod to the stereo.
2. The Second part is muting the radio signal
1. This process does involve soldering your AUX 3.5mm jack to the tape deck control board (PL-17 on the electrical schematic). You will need to solder the Right-Left and Ground wires to the board. This will allow the signal to go through your stereo unit.
2. You will have to mute the radio signal (as you will have two signals going through your unit, one from your radio and one from your iPod). This is done by activating the mute signal on your board. (essentially simulating what happens when you enter a tape in your tape deck). What happens is a 8.5 volt signal is sent to mute the radio signal. What you have to do is solder in a switch that allows you to turn on/off the 8.5V to the 'radio mute' allowing you to go from your iPod signal back to your radio signal. This method still allows you to play your tapes. There are other methods that I came across that permanently hack you tape deck.
This method gives you the best quality sound output. FM transmitters/tape adapters will not give you the quality sound this method does.
I did not find any AUX plug and play style connectors for the 8 din pin connector these stereos have. To my knowledge these are used for output only, meaning it sends a signal from your stereo deck to amp or equalizer. I don't think you can use it to at input to your unit.
There is nothing better than having the original vintage radio in your 911 but still being able to play your tunes from your iPod.
I could do this for you, but I am from Melbourne Australia, shipping would be around 100 return.
Cheers
dobrjan
Old 04-25-2013, 11:34 PM
nineball's Avatar
get a wired fm modulator. it plugs inline with your antenna. very easy to do.
Metra 44-FMMOD03 (44fmmod03) 2-Channel, Universal FM Stereo
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 04-26-2013, 09:08 AM
Exotic Vehicles are here
1-ev.com's Avatar
We've used This setup on all our cars, works like a champ, and it cost = $50 Plus my $$$ labor
Belkin Bluetooth Music Receiver:
Belkin connected to this "PAC IS31 iSimple Universal Auxiliary Input for FM" or similar , witch connects to any radio:
You can use this instead of iSimple http://www.amazon.com/Blaupunkt-AUX-2-Second-Auxiliary-Adapter/dp/B0002IEAME/ref=pd_sim_sbs_e_3
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 04-26-2013, 09:54 AM
Dial 911
A horse with no name's Avatar
Would like to try it.
Cheers
dobrjan
Hi Dobrjan... I would like to do what you have explained but to a Blaupunkt 'New York SCD 08'. The CD player is one that you have to put a CD into an individual cartridge then into the player... Not a good system. It quite working some years ago and it really is not worth the price they want to repair it.
At the moment I am using my iPod -Touch directly off of the aftermarket amp. It works OK in that the radio 'powers' the amp on but I have to control the sound through the itouch... To be able to do so through the radio would be great.*
I do have the service manual that includes all of the schematics... Would it be possible for me to email them to you to have a look at? If so after perusing them
I would appreciate it if you could advise me where I should solder the ground wires of the iPod touch AUX jack to on this 'New York' model, including of course where to solder the switch to for the iPod - Touch signal.
Maybe best to PM me - Thanks.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 04-28-2013, 10:03 PM
Hi Horse w/o name you seem to have broken thru the rails and strayed onto my side of the track ......
Anyone actually added an Ipod direct input to a Blaupunkt Reno ?
Old 04-29-2013, 04:06 AM
1-ev.com's Avatar
My set up will work with ANY radio: How Do I Add Ipod To Blaupunkt Reno ?
also, nineball setup is similar How Do I Add Ipod To Blaupunkt Reno ?
+ '68 911
Old 04-29-2013, 10:04 AM
Eng-o-neer
Tremelune's Avatar
It doesn't look like these solutions do AVRCP (which allows you to control the iPhone via the head unit). At least with my iPhone, that makes it a dangerous deal-breaker. That said, to start wiring your head unit such that it would control your iPhone would probably take some reverse engineering, soldering, and an Arduino...
For my E30, I left the stock radio in the dash (disconnected) and put a modern head unit in the glovebox where I couldn't see it. I wired an IR receiver and just use a little remote to control everything. It is not ideal, but it works well and is receptive to future changes.
For my Porsche I just got over it and put in a Pioneer DEH-PRS80. It behaves as expected and will go completely dark after five seconds of use so that I don't notice it, particularly at night.
Old 04-29-2013, 10:53 AM
Dial 911
Hee Haw!...I only jumped out of a smaller corral into a larger one ...Still kicking 'to be free'
Being that your radio has a cassette player, Dobrjan's way of going about it seems to be the way to go for a direct hook up with full control... He wired his direct to an Atlantic 47 which also has a cassette so it should work for a Reno.
Unfotunately I haven't yet heard back from Dobrjan to see if it is possible to do the same to mine. You can down load the complete service manual that has the complete schematic on line - I think I paid $10.00 for mine.
I did have a car with a CD player some years ago, and what worked very well was an adapter that had a cassette blank wired to it. I had purchased it at BestBuy.
At the time I had a 'mini disk' mp3 player that I plugged into it...As I was saying, it did work well. Other than that I understand that you only have the option (best) of Dobrjand's way, an FM unit, directly off the amp but with IPod touch control only....And of course a new rado that comes with an iPod Aux
I recently read that a Reno has and Aux. output for a CD player...If that is so, then I would think that it may provide a solution .
'Nineball ' is a real true radio guru so maybe he could tell you/us more about this CD Aux on a Reno.
A little edit here...While tapping this out ' Tremelune' has added another option...
Cheers!
Leonardo Da Vinci
Old 04-29-2013, 11:08 AM
nineball's Avatar
as far as i know there is no aftermarket solution that will enable something as old as the head units in our cars to actually control an ipod. our units are 25-40 year old technology, they just don't mesh.
the only solution i have ever found appears to be nla. it was a kensington liquidaux deluxe and i still run one in my car. it was a charger/holder for the iphone/ipod that gave you an aux-out line, but it came with a little remote that gave you the basic ipod functions (track forward / back, play / pause, stop). here is the link but like i said it is nla.
Amazon.com: Kensington LiquidAUX Deluxe Auxiliary Car Kit with Remote for iPod; iPhone 1G, 3G: Electronics
Old 04-29-2013, 11:50 AM
How do you open the stereo case up ? I just had a Reno shipped to me and it needs some off the contacts cleaned and I would like to see what is involved in wiring an I-pod jack. Someone has been prying at a couple of spots on the case and I want to avoid adding more marks to it.
Old 05-04-2013, 09:55 AM
Swap it out. Put in a Blaupunkt Toronto BT400 series. Plug n Play!
Old 05-04-2013, 10:14 AM
Would if I could, but in BC Collector plates save a LOT on insurance. Rules say any radio has to have been available +/_ 2 years from build date.
Old 05-04-2013, 11:17 AM
RETIRED
Joe Bob's Avatar
Woody's on eBy sells modified peiod correct radios with iPod jacks. Bet you can pick one up and exchange it...keep the original or sell it to recover costs. You could break even.
I bought one for my 356. Worked as advertised......also one for one of my 914s.
2012 ML350 3.0 Turbo Diesel
Old 05-04-2013, 12:49 PM
Eng-o-neer
Tremelune's Avatar
...What?
Old 05-05-2013, 06:41 PM
Government insurance in BC. To qualify for collector plates ( about 1/4 the insurance cost of normal) there are rules.
"Your vehicle must be
*25 years old or limited run, or orphan
* in exceedingly good condition (for example, no dents, scratches, rust, chips in the paint, visible primer, tears in the interior);
* in a condition that conforms to the original manufacturer's specifications (no non-approved parts and accessories added); and
* maintained in the same condition when originally approved for collector plates."
when you read more details "tires must be within 1" of stock size, only aftermarket add ons that could have been installed when car was new, and stock radio or one that could have been installed within +/- 2 years. They are very fussy. I had to send 16 pictures, at the angles they stipulate, with the form. Still waiting to see if they approve
Old 05-05-2013, 11:23 PM
