Anyway to confirm 2.7 punched out to 2.9L?
I was told my 911 has a 2.9 liter, some sort of upgrade kit to the 2.7 liter. Is there anyway to confirm this without records, or taking the motor apart? Thanks!
There's no such thing as a 2.9 upgrade kit. Which could be why there is no paperwork on the engine work.
Sandy 1969 911E 1970 240Z Last edited by SandyI; 04-25-2013 at 09:34 PM.. |
I stand corrected. Sorry.
Sandy 1969 911E 1970 240Z Last edited by SandyI; 04-25-2013 at 09:41 PM.. |
Fastest and simplest way is what they use for Formula cars in racing.
Take out 1 spark plug....back off rocker arms for that cylinder...fill with alcohol (cylinder) when piston is all the way down...put graduated cylinder in spark hole...top up fluid to lower mark (you decide base line) and rotate crank slowly...when fluid gets to its highest point...measure the volume...multiply by 6...presto...engine capacity! Bob
Bob Hutson |
Air Medal or two
Look at the bore for cyl jugs . a 2.9 is much larger and very too close to the studs. thats why is not done too much.
Or if you know the two different hole sizes...a 2.7 jug will be very loose in there...
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Mo money = mo parts
I would say not easily. This old thread suggests that they did not machine the case to accept bigger jugs, so you will either need to do what HawgRyder suggests or some how measure the bore and stroke.
2.9L Conversion
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Or just use logic. If it's been taken up to a 2.9 it will have a lot more poop than a stock 2.7. If it was a performane upgrade it's likely that there would have been conversion to carbs, cams, chain tensioners, etc. With all those changes you're really going to feel it in the seat of your pants.
-C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Air Medal or two
AFAIK. they all used bigger cylinders.
To get .3 bigger that will leave thin to no cyl wall ?
gearhead
Ferg's '75 US Carrera pulls as hard or harder than many 911SCs I've ridden in.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Well then you could ask someone more experienced. We're spoiled here in P'town. Steve Weiner or Jeff @ Rothsport could likely tell you without even driving it....
That aside, does it really matter what the exact specs are? How does the car drive? Are you lap times acceptable @ the track?
Speed Dog's Chauffeur
Expensive upgrade not to have receipts?
Andial 2.7 to 2.9 parts & installation are not cheap so most people would have kept some paper trail. About the time the 3.2 came out in 84, some used SC 3.0 motors were available so spending big $$ on the 2.9 upgrade? Gotta measure volume or cylinder fit to be sure. If you have a certified stock 2.7 for a visual on the cylinder to stud clearance, that would be the simple way. If it runs good: drive it. Best of luck.
Air Medal or two
Like i said earlier..I do not think you can bore a 2.7 set of jugs to 2.9
