redstrosekNic's Avatar
Accumulator to Filter line
Hey everybody!
My metal fuel line running from the accumulator to the filter appears to be a tiny bit "kinked". Is this a normal bend, or should I plan on replacing this line with the filter? I cannot seem to find a replacement part, though...
Dustin
Old 04-26-2013, 01:05 PM
Senior Advisor
James Brown's Avatar
i fail to understand what the problem is. good photos, i assume it is on the 75 S were talking about. Does the car run now? any problems with fuel flow? those fuel lines are NLA so treat them like gold. you can have them made up from a shop. but i think your ok.
08 Cayenne Turbo
Old 04-26-2013, 01:57 PM
Thanks for the response. It appears as if the line is a bit smaller in diameter in the bend than it should be. The top photo shows this better than the bottom. Perhaps I am being paranoid, as the car runs fantastically.
I just happened to notice what I thought is a slight kink in the line where it bends. Like I said, the car pulls hard (better than what I thought a 2.7 would), and has no running/ fuel issues that I am aware of. I was just curious if the bend looks normal to everyone.
Dustin
Old 04-26-2013, 02:08 PM
ROW '78 911 Targa
timmy2's Avatar
Looks like a normal bend for that short of a line with a radius that tight. Must be why they changed them a year later...
Old 04-26-2013, 02:14 PM
E Sully's Avatar
A couple of pictures of mine for comaparison. The change in fuel filters made this NLA.
Ed
1973.5 T
Old 04-26-2013, 04:03 PM
^^^Thanks for the pic! Mine does look as if it is bent at a more extreme angle. I'm hoping the fuel system isn't stressed in some way because of the tighter bend. It is hard to tell how smooshed the line is.
Dustin
Old 04-26-2013, 04:28 PM
