Dumb Error on throttle linkage
Well in modding out my engine the linkage rod from my throttle to the rod that goes to the assembly next to my tranny became undone. In fooling with it I think i screwed the whole assembly up (did not connect it correctly) because now when I push the gas pedal down it stays down and does not spring back. Also from the motor side, when I manually move the throttle and spring, the gas pedal does not move.
Everything was working before the rod that goes from the throttle thru the firewall and then links up near the tranny became disconnected. Does anyone have a pictures of how the throttle body linkage is all connected, along with how the throttle body with spring is supposed to look and correctly connected. There is something I did wrong in hooking the rod and everything up because like I said everything was working fine before. I just need to see pictures of how everythjing is supposed to look like connected correctly. And yes, I posted this after doing a search on the forums for an hour and I did get some info Any help would be greatly appreciated. |
what year car? does it have carburators?
GIno:
Thanks for giving me the heads up. I forgot to put that it is a 1987 Carrera |
don't have first hand knowledge on a 3.2
here's a pict I found after a quick search. http://forums.pelicanparts.com/uploa...1367182058.jpg |
Gino:
But that is what is confusing me. In the above picture the linkage is connected to the V pointing up wards. That is the space forming the V is facing up. But in other threads I researched people said the V opening should be facing downwards or to the sidelike in this picture |
Just went out and took a few pics for you,hope it helps !
Cheers ! Phil http://forums.pelicanparts.com/uploa...1367186634.jpg http://forums.pelicanparts.com/uploa...1367186659.jpg http://forums.pelicanparts.com/uploa...1367186679.jpg |
Thanks so much for going thru all of that trouble. So that gives me an idea of how the throttle body (engine part is supposed to look. What is really throwing me is how does the connection of the rod down by the trnny supposed to look. Is my V arm supposed to be pointing up or down. Here is a picture I found of the connection near the tranny. IS this the correct positioning of the Vshaped lever http://forums.pelicanparts.com/uploads13/ACC1215403217.jpg One last question: How many springs are there supposed to be on the throttle body assembly. I only had one when I put things back together, Am i supposed to have two springs |
This must be your lucky day ... lol ... my car is on stands in the garage so i took a few more pics for you !The curved part of the lower linkage goes over the axle and into the engine bay.
The extra spring you see at the gearbox linkage is my home made "no more hanging throttle" fix ... works very well :) Here you go ! http://forums.pelicanparts.com/uploa...1367189243.jpg http://forums.pelicanparts.com/uploa...1367189289.jpg http://forums.pelicanparts.com/uploa...1367189320.jpg http://forums.pelicanparts.com/uploa...1367189363.jpg |
Wildcat:
You are a life saver. Those pictures are exactly what I needed. My last question goes to the engine bay where the actual throttle body is. On that assembly how many springs do you have on the throttle body itself. DO you have one or two springs (don't count the one by your tranny) |
I might do that when the engine go back in... next week-end :rolleyes::rolleyes::rolleyes: If it is a CDN Tire on, send me the SKU :) |
JJ,so you like my fix :) I think i picked up the spring at Rona in the hardware section ! Actually CDN Tire has a good selection in the lawnmower/tractor section as well ... It doesn't need a lot of tension,just enough to snap the throttle pedal back ! Cheers ! Phil |
Oui, quel moteur... 3.? :)
JJ,
I will remove the 3.6 evidence in my signature for now as my track gang doesn't know about it yet ... i want to see the look on Matt's face when i run down his 993 between Carroussel and turn 10 at LCMT :) I'm going to email you some pics tonight ! Cheers Phil |
Tabarnacle, I hope they don't read this...
Could delete the post |
Wildcat:
Thanks for the followup on the spring matter. Based on everything you sent me I should be able to now troubleshoot my problem. Thanks everyone |
ETA link with lots of photos. http://forums.pelicanparts.com/911-engine-rebuilding-forum/203902-3-2-throttle-return-spring-differences.html |
Okay I went to the cite that you posted and I could clearly see the two springs. But where do they hook to. I see where you wrote "Spring runs from bracket at back(front) of the engine to a hole cast in the bottom of the left side intake." From the pictures you referenced it appears that there are two bottom springs + the top spring making a total of three springs. So, now I am really confused and lost. I have 3.2 liter engince, 87 Carerra. Could you really help me out on this spring thing because I am not getting any action on my pedal |
On my 86 I have two springs total. One on the throttle body and one underneath the intake. I had no idea some cars had two under the intake until I searched and found that thread. My spring under the intake is similar as the left/outboard one pictured in the linked thread. I'm on an I-pad so I'm not even gonna try and paste in photos.
The spring connects to the linkage on the back of the engine. It's hooked to the rod that runs from the side of the trans up through the engine tin. My visualization is that it pulls on the rod when you release the accelerator pedal. It's tough to see with the engine all together and installed. If yours was set up this way and the spring broke you'd never see that unless you knew to look. I recently replaced intake gaskets and it was fun getting that spring re-installed. With the auxiliary blower and tubing removed you have better access. I still had to resort to a seal puller(hook) and pliers to re-install. -J |
Porboynz Yes it does move. When I push the rod it moves the pedal and vice versa |
That's cool then, now to get the bell crank on the gearbox sorted and the rod up to the injection. It will only work properly in the correct orientation, Porsche is good like that. Finding that correct position can be infuriating. Porsche is not so good like that. Take you time, look at how its set up and you will figure it out.
Everybody knows you bought the motor that was on Rennsport.ca. Good luck catching Matt with his re-gear.....just sayin' |
WELL ITS FIXED!!!!
And I came on here to thank everyone of you guys who jumped in to help me. The problem was as everyone identified was that I was missing two tension springs that go on the bottom of the 87 3.2 engine. With my engine there are a total of three springs associated with the throttle body. I had one return spring, but there were two tension springs that connect to the intake (I believe that's right). But after I purchased all new springs and put them on per the pictures provided by you guys my gas pedal worked like it should. So again, thanks everyone. You guys went to your engines and took pictures and referred other threads. What a great set of guys. |
| All times are GMT -8. The time now is 08:33 AM. |
