Tadpole's Avatar
Blinker and flasher problem
I'll start by saying that I took the P-car to Hershey. It ran great and had a great time. Bought a few small pieces and although it was windy it did not rain on saturday...yahoo.
Now for the problem. Took the car to work everything was fine. Left work and had no blinkers and flashers. Things that I also noticed.....when the parking brake is on the red light does not come on anymore. Also when the high beams are put on the blue high beam indicator light does not come on. Fuses are good and all other lights are working. There is no relay sound either. Help Thanks for any and all help.
Mike
'75 911S
'76 911S
Old 04-29-2013, 06:21 PM
Send a message via Skype™ to Porboynz
Check the earth wire to the guages
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 04-29-2013, 11:51 PM
Tadpole's Avatar
Hey guys, just as a follow up to my problem. I pulled a couple of gauges out to check the grounds. All seemed good. Started following the wires back to see if I could find the problem. Low and behold I found that the male /female connector under the dash had come apart. Plugged it back in and I am back in business, except for the high beam indicator light still does not work. Will have to do some more poking around. But for now all is good. Thanks
Mike
'75 911S
'76 911S
Old 05-01-2013, 06:06 AM
