89 SC clutch Cable
Had the 911 out for a drive today, pushed in clutch to shift gears and pedal went to floorboard. Had it towed home and looked at it. I found that the pin through the clevis had sheared off. Do I have to remove attachment at helper spring or can I do repair with new pin and bushing?Appreciate the help. Thanks. It is getting tougher for my 63 year old body to lay under the dash.
Clutch pin
If you haven't already done so, now is a good time to do a rebuild on the pedal cluster. The only really irritating part of the job is the R&R on the clutch spring. Remove, disassemble, clean, paint and put in new bushings. You will be amazed at the difference in the pedal feel! Good luck!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
UnRegistered User
I had put a clutch cable in a couple of years ago and it was a bear to work around the pedal area. It seems that it would be a good idea to pull the drivers seat to get a bit more room to move.
I wasn't smart enough to do that so I worked on my under dash yoga poses...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Did the pin shear or did the hole it goes in on the clutch pedal wear through?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Recreational Mechanic
+1 on pedal cluster rebuild plus new clutch cable and clevis.
If your car is an SC (not 89!!) and it has never been done, it's time. Factory bushings were plastic, age is now more of a factor than mileage. Replaced with Bronze bushing kit from our host.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
on some cars, i remove the steering wheel for easier access.
Remove the pedal assembly, assess the damage, purchase a set of o.e. PLASTIC bushings from the dealer, or other source, and disassemble the pedal cluster. You will probably have to buy a replacement clutch pedal shaft, because the clevis pin bushing probably wore out years ago, and now the pin has worn through where it attaches at the pedal shaft. Also, prepare to replace the clutch cable at the same time. CAUTION: Do not buy an after market cable, only use a factory replacement. The search button will find you a thread where I've mentioned this before.
Keep the Shiny Side UP! Pete Z. |
