Need help for 80 SC rebuild
Hi I m doing front suspensions rebuild now , since I remove all the front parts, I see most brake line are rust at end , my question is should I replace all the rust brake line or do I just give a clean And should be fine ? . Thank you
KJ, I'm a Kiwi, so I'm pretty rough.
But what I do if it's only surface rust and the brake lines are fine. I scrub them down with a scotchbrite and fishoiline oil ( https://www.1stopbuild.com/goods-45651.html ) then clean them with paint thinners and put on some of that rust convter stuff. I let that cure then put on some Fishoiline. The repair places always want to put a join in and I see that as a point of failure other than the original minor rust problem. Just my opinion. |
thanks bill , i just take some photos . it better with picture
They don't look compromised at all. i'd do the above mentioned clean and keep a bit of fishoiline or similar on them. they may be a PITA to undo at sometime, but worry about it then.
Again, just my opinion. The other guys may have some better ideas. Where are you in Sydney, I'm a bit of a fan of the place? |
