-   -   Building a Trans Cooler - need to ID and Find bits (http://forums.pelicanparts.com/porsche-911-technical-forum/74830-building-trans-cooler-need-id-find-bits.html)
widebody911 07-17-2002 12:22 PM
I've decided to build a trans cooler setup, and I think I can do it for less than the $600 that AutoMetrics wants for theirs. Plus they won't reply to my emails, which torques me.
If I can ID this fitting and figure out where to buy it, I can do the rest myself. I have an extra cooler laying around, and can source the line locally. The Tilton pump is an off-the-shelf kinda item.
http://www.autometricsmotorsports.co..._diff_pump.jpg
Jack Olsen 07-17-2002 12:28 PM
You might want to check with Racerpartswholesale.com. Also, the company that manufactures those fittings probably has a location in San Francisco. When I did my second oil cooler, I was able to drive out to their plant for the fittings I needed.
My system uses (I think) a Tilton pump and an oil cooler from a 944 Turbo.
Chuck Moreland 07-17-2002 12:36 PM
What's a good source for the Tilton pump?
How about a spray bar?
widebody911 07-17-2002 12:52 PM
Anyone know the size and thread of the drain and fill plugs?
Early_S_Man 07-17-2002 03:15 PM
Thom,
M24 Taper for the drain & filler.
Try an industrial hydraulic supply ... they may not have it in anodized aluminum, but Aeroquip makes steel fittings of all kinds for trucks and industry!
