Building a Trans Cooler - need to ID and Find bits
I've decided to build a trans cooler setup, and I think I can do it for less than the $600 that AutoMetrics wants for theirs. Plus they won't reply to my emails, which torques me.
If I can ID this fitting and figure out where to buy it, I can do the rest myself. I have an extra cooler laying around, and can source the line locally. The Tilton pump is an off-the-shelf kinda item.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Administrator
You might want to check with Racerpartswholesale.com. Also, the company that manufactures those fittings probably has a location in San Francisco. When I did my second oil cooler, I was able to drive out to their plant for the fittings I needed.
My system uses (I think) a Tilton pump and an oil cooler from a 944 Turbo.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
What's a good source for the Tilton pump?
How about a spray bar?
Chuck Moreland - elephantracing.com - vonnen.com |
Anyone know the size and thread of the drain and fill plugs?
Thom,
M24 Taper for the drain & filler. Try an industrial hydraulic supply ... they may not have it in anodized aluminum, but Aeroquip makes steel fittings of all kinds for trucks and industry!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
