Early 911 dash clock disassembly
Does anybody know how to disassemble the dash clock as shown on the picture? The white housing will not come off.
Thanks! PT |
http://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair.htm
Everything is here at pelicanparts.com !!! Brett |
Dutchfly:
You have to break the seal, the round plastic cover, to get at the nut inside it to unscrew it. That is a way of telling if someone opened up the clock. Why worry it dosn't work anyway. Mine had plastic gears melted together from the overheating. Good luck, Ron D
RonD 69912T |
