Hennessy (guest)
Guest
Posts: n/a
tips on how to change air filter on 997 S
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing the Air Filter - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-09-2013, 12:27 PM
Nick at Pelican Parts's Avatar
It's not that bad. You have to disconnect the electrical connector, then thw two rubber hoses, remove the air cleaner fastener, then lift the air cleaner out of the engine compartment. Be sure nothing is attached or snagged as you lift it out. Once out, open the air cleaner and replace the air filter element.
- Nick
