| bazar01 |
05-09-2013 12:55 PM |
Originally Posted by Tito (guest)
(Post 7432495)
I have replaced all the engine belts because the engine belt light came on. The light is still on, do I need to replace the belt tension sensor. Should I get a new one or can I get a used one. 964/1989 porsche carrera c4 3.6
The belt sensor is actually a sensor for a broken belt. If both belts are still intact there is something wrong with the microswitch inside the belt sensor.
You should get a new one because you'll never know how long a used one has been on the previous car. Or just jumper the connector and replace the belts regularly like every 2-3 years for street use. Older 911 don't have them.
